Go to Post It's not a rendering mistake, it's a design challenge! - Eric Scheuing [more]
Unread 14-01-2009, 19:07
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Outpost seat position
Originally Posted by ScottOliveira View Post
Tongs are provided for the payload specialists for retrieving game pieces through the hole. I believe they are supposed to be 36".
What I've read indicates that tongs are at the fueling stations. I've seen no support for them being available at the outpost. Can you point me to where you're seeing this?
Originally Posted by Vikesrock View Post
Okay, here's what I have calculated for the location of the Outpost Seat [...] 37.75"
Awesome... thank you for this. Now, seeing as how the center of the hole is 37.25" off the ground, am I correct in figuring that not even Michael Phelps would be able to hand an empty cell through the hole while buckled into the seat?
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 14-01-2009, 19:18
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
I guess that depends on the height of the chair. 37" is a long reach, though I know someone who could reach that without much trouble.
To note, I'm fairly average size, and my shoulder to fingertip length is 33". I can lean forward more than 4" easily with just a seatbelt on.
Wetzel
Viva Olancho!
Unread 14-01-2009, 23:10
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
I would hope they are positioning the seat based on the person using it. That may be why there is no specification on the seat from the wall.
Sitting in the seat Indian-style, your knees should not be touching the wall, but yet you are close enough to use the tongs to pass a ball to the robot through the opening.
Simple geometry of the human physique states the outstretched arms from finger tip to finger tip equals a person's height. Half of that will be in the lower extremity. If you are shorter than than the norm, you will be sitting a little closer than somebody 6'6".
The intent is probably that everyone will have the same ability at the hole through the wall, but I think taller individuals would have a slight advantage throwing them over the wall.
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 15-01-2009, 00:10
There are no "tongs" in the outpost. The Nifty Nabber "grabbers" are installed in the fueling stations.
"reloading" the Outpost smcmahon Rules/Strategy 28 16-03-2009 20:24
2005 seat motors?? erniep Motors 2 24-01-2005 18:56
Seat Motor Wiring zainali Electrical 3 15-02-2004 15:22
Seat Motors are back! dez250 General Forum 2 10-01-2004 21:46
Spare Seat Motors archiver 2000 2 23-06-2002 22:21
