Go to Post We are here to support each other. - Mike Martus [more]
Unread 14-01-2009, 21:39
JHale JHale is offline
JHale is an unknown quantity at this point
[Windriver] Getting error on run: Download Failed
Hey all!
I am having a lot of trouble getting Windriver to work. Everything was going good until I tried to run the code.
I clicked the little debug thing, setup the insertion point as per the manual, and hit Run. I get this error:
Download failed.
Module: C:/WindRiver/workspace/CSimpleTemplate
Target:  [info about our controller]
Possibly Caused by:  Unknown File Error: C:/WindRiver/workspace/CSimpleTemplate
It does the same thing regardless of which example we try to use.
Any help is appreciated!!
Unread 14-01-2009, 21:46
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: [Windriver] Getting error on run: Download Failed
Download Failed Means that is did not connect to the bot.
Did you:
connect to the system in the (default location) lower left target sys box?
set the download options (enter FRC_UserCode.... and {Options=0x1000010}?
if not the second one, right click on the project on the left, and Debug/Run kernel task, and put in the info in the C_Programming_Guide.pdf (i bileve that is the name) specifies.
If you did both, can you ping the cRIO?
Watchdog.Kill();
Unread 14-01-2009, 21:56
I don't know what you mean by ping the cRIO (with cmd prmt?).
I do connect and disconnect just fine.
Everything is set up including the advance options string. (Although it didn't appear in the manual). Am I reading an old manual?
Still no luck though.
ping cmd:
Microsoft Windows [Version 6.0.6000]
Copyright (c) 2006 Microsoft Corporation.  All rights reserved.
C:\Users\James>ping 10.17.99.2
Pinging 10.17.99.2 with 32 bytes of data:
Reply from 10.17.99.2: bytes=32 time<1ms TTL=64
Ping statistics for 10.17.99.2:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 0ms, Average = 0ms
Unread 14-01-2009, 22:09
Getting further.
I no longer get the unknown error, but now I get a massive list of unresolved symbols.
Am I missing some include path?
Unread 15-01-2009, 07:42
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Originally Posted by JHale View Post
Getting further.
When you download a module, vxWorks needs to connect all the unresolved references in your module.
For example, if your module calls a function named 'foo', then vxWorks must be able to find an address for 'foo'.
The function 'foo' might be part of the vxWorks kernel or it might come from other modules that have already been downloaded.
Include paths are a compile time issue -- where does the compiler look for header files.
Unresolved symbols is a link time issue (in this case dynamic linking) -- the linker is unable to find some data object or function.
Of course, with C++ name mangling, it can be tedious to figure out where the unresolved symbols are supposed to come from.
It may be that you need to statically link your module to some library.
Getting Familiar with Programming in WindRiver kyungjin C/C++ 35 17-01-2009 13:04
Getting Live Feed from Axis Camera in Windriver Inoperational C/C++ 8 15-01-2009 01:21
Getting Started in Windriver C/C++ 7-11number1 C/C++ 3 10-01-2009 21:46
Strange WindRiver Error Maxpower57 Programming 1 10-12-2008 21:41
Basic Run Error BBFIRSTCHICK Programming 10 02-04-2003 22:43
