Go to Post Ohh the [strike]humanity[/strike] robotity! - artdutra04 [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition
Unread 15-01-2009, 09:06
smcmahon's Avatar
smcmahon smcmahon is offline
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
smcmahon is an unknown quantity at this point
Re: LabView dashboard/live telemetry
Well. We updated LabView and the cRIO firmware. And we finally got our programming laptop in, which has 4x the RAM of the one we were using. So now, when we run it, everything works great. We're getting the live feed from the camera, and can move the robot at the same time. Impressive stuff. Thanks for advice.
Unread 15-01-2009, 10:04
Chaos in a Can Chaos in a Can is offline
Joel Spadin
FRC #1736 (Robot Casserole)
Chaos in a Can is an unknown quantity at this point
Send a message via MSN to Chaos in a Can
While getting a more powerful computer is definitely the way to go, if anyone has problems with the dashboard maxing out CPU, you could try placing a wait inside each of the loops.
You won't recieve telemetry as often, but it should reduce the load on the processor.
(Look at the timed loop at the bottom of the basic robot code for an example.)
2006 Xerox Creativity Award
2007 General Motors Industrial Design Award
2008 Judges' Award
2009 Chrysler Team Spirit Award
Unread 15-01-2009, 11:17
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
I should have added the suggestion from Chaos in a Can to my earlier post. That's a VALUABLE lesson in LabVIEW development (and, I'd imagine, any multi-threading application that needs to share time in an OS).
You should always make sure that loops only execute at a reasonable rate. Without adding an intentional delay within a while loop or using a timed loop (which does this for you), the loop will execute at max speed and cause the OS and CPU to max out.
As an example, create a simple while loop with only an increment and display and then run it. You'll find that it will execute at a few MHz and cause your PC to slow down tremendously. Add a 1ms wait in the loop to force it to execute at 1kHz and everything will be fine.
Russ
Unread 17-01-2009, 22:17
stevethetinker stevethetinker is offline
FRC #1288 (RAVEN)
stevethetinker is an unknown quantity at this point
I had the dashboard demo (the one in LV in projectwizards) working a couple of weeks ago, and now when I try to build it it says the vi is broken. Has anyone encountered this problem? Is there a fix short of reinstallling LV?
Unread 18-01-2009, 08:47
Have you installed the latest LVUpdate and reimaged both the cRIO and DS?
http://joule.ni.com/nidu/cds/view/p/lang/en/id/1180
If you have done the installation recently, my understanding is that you'll need to open a new FRC project and "import" your custom VIs. Without going through the "new project" process, you may have some bad links to sub-VIs.
Another option is to press the broken run arrow and let LabVIEW point out where the problem is. It shouldn't be too hard to track down the issue.
Russ
Unread 19-01-2009, 19:45
FRC #1288 (RAVEN)
I have the latest and have reimaged. I did as you suggested about finding the problem and came to a 'well duh' moment. I was trying to build the template. I had forgotten to go to the labview main dialog and create a dashboard project. When I did that it worked.
Labview Dashboard Peter Randall NI LabVIEW 3 07-12-2008 10:29
Labview Video Tutorial? Dashboard Chris_Elston National Instruments LabVIEW and Data Acquisition 21 25-01-2008 00:29
Labview Dashboard and updated IFI dashboard spec Joe Ross LabView and Data Acquisition 1 04-04-2006 02:04
LabView Dashboard brummer_13 LabView and Data Acquisition 7 08-02-2006 21:43
LabView Dashboard Problems brummer_13 LabView and Data Acquisition 11 01-02-2006 20:13
