Go to Post Everybody "cares about the robots" - otherwise we'd be doing science fairs. - Taylor [more]
  #31   Spotlight this post!
Unread 14-01-2009, 22:49
spc295 spc295 is offline
FRC #0295 (Renevatio)
spc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to behold
Re: Shooter vs Dumper Trade Study
Originally Posted by gburlison View Post
I think that shooters dominated Aim High because the top goal was worth more points. With the balls worth the same amount, I think that either design can be effective. I think that a good dumper will be easier to build, so I expect to see more good dumpers in the finals of Lunacy than there were in Aim High.
I agree. but I would also like to say that I think a dumper on a turret will be the best. because it does not matter how you pin an opponent
295 Team Captain
  #32   Spotlight this post!
Unread 14-01-2009, 22:51
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
Thanks for making that rule clear for me
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
  #33   Spotlight this post!
Unread 14-01-2009, 22:58
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Regarding the PAYLOAD SPECIALIST retrieving balls....the tongs must be used to get balls from the AIRLOCK to the FUELING PORT....so even though you can dump balls into the AIRLOCK as fast as you want, the PS probably can't put them into play very quickly.
  #34   Spotlight this post!
Unread 14-01-2009, 23:05
CDH Jeff's Avatar
CDH Jeff CDH Jeff is offline
FRC #2450 (Raiderbots)
Team Role: Electrical
CDH Jeff is an unknown quantity at this point
my question is, anyone here ever heard of a shotgun?
"why are 'standard' and 'metric' different?! metric should be the standard!"
  #35   Spotlight this post!
Unread 14-01-2009, 23:22
647techangel's Avatar
647techangel 647techangel is offline
K.I.S.S (Keep It Simple Stupid!!)
AKA: Tech_Angel
FRC #0647 (Cyber Wolf Corps)
Team Role: Driver
647techangel has a spectacular aura about647techangel has a spectacular aura about
i think making a dump bot is sticking to good old K.I.S.S , because if you think about it you have 3 "shooters" already (payload specialist).
!!!!647 HOOAH!!!!
  #36   Spotlight this post!
Unread 15-01-2009, 03:27
redbarron's Avatar
redbarron redbarron is offline
Mike Barron
AKA: Mike
FRC #1270 (Red Dragons)
redbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to behold
We have been debating on how to score since kick off but have decided to go with a shooter. When you are a dumper you are relying on getting close to the opponents trailer. Though you can can score more balls at once you will be sitting still while dumping. I am in no way saying that there will not be a team that will pin a bot and dump their load in about 5 seconds, but it will be kind of sad to see for example a load of 7 moon rocks get "dumped" as a super cell lands in the dumping robots trailer resulting in -1 points for the load of seven you just worked hard to get rid of. A shooter can be run at low speeds and if the balls are delivered to the shooter fast can be just as, if not more effective than a dumper.
Just my .02
The Red Dragons
2005 Buckeye Regional Woodie Flowers Regional Award
2005 Florida Regional Finalist Along with 1251 and 845
2006 Palmetto Regional Engineering Inspiration Award
2007 Florida Regional Judges Award and Regional Winners Along With 1251 and 86
2007 Curie Division Winner with 330 and 910
2008 Florida Regional Team Spirit Award Winners
  #37   Spotlight this post!
Unread 15-01-2009, 08:16
ScottOliveira ScottOliveira is offline
FRC #3455 (Carpe Robotum)
ScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really nice
Unfortunately those shooters are immobile. The robots have to come to them to be in accurate range. While they can be pushed, remember that it means your team's robot(s) are right next to it, and a shot slightly off aim could easily land in one of your team's trailers (it doesn't matter who throws it, a ball in your trailer counts for the other team).
A robot capable of scoring on its own (if built correctly) almost completely negates the possibility of scoring on itself (although it could still hit a team mate).
  #38   Spotlight this post!
Unread 15-01-2009, 08:21
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
Originally Posted by redbarron View Post
.... I am in no way saying that there will not be a team that will pin a bot and dump their load in about 5 seconds, ....
Just my .02
5 seconds is an eternity for a good dumper design. all of our prototyping says that we should be able to dump 7 balls in about 2 seconds. (not counting the time it takes to chase down and pin an opponent of course)
  #39   Spotlight this post!
Unread 15-01-2009, 09:38
I think the dumpers will do better, because a shooter has to deal with broken orbit balls, the dumper just uses gravity.
295 Team Captain
  #40   Spotlight this post!
Unread 15-01-2009, 09:41
Aren_Hill's Avatar
Build Nifty Things
not all dumpers will just use gravity, teams who really want a good dumper are gonna figure out how to effectively "hurl" the balls out of there robot quickly and in large quantities
A guy who likes robots.
  #41   Spotlight this post!
But a dumper will have to deal with them too. If the dumper has any way to refill, whatever collection mechanism it uses will have to be able to deal with them. And whatever hopper it uses will have to be designed that broken balls do not get stuck/cause a jam.
  #42   Spotlight this post!
Unread 15-01-2009, 09:57
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
Have there been any videos posted of dumpers? I'm curious to see if there is any cloggage or missing because the balls are interacting with each other as they come out...
We're probably going with a short range shooter; tests show it's very accurate, and at a rate of ~3-4 balls per second, we should be able to unload just a little slower than a dumper... just with the added benefit of being to start earlier Not that dumpers aren't a viable strategy. I predict we might see one on Einstein this year.
  #43   Spotlight this post!
Unread 15-01-2009, 10:16
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
In this thread, what is the definition of dumper ?
a - a low dumper, over the wall in the corner
b - higher up, into a trailer
c - higher up, into the trailer and the corner
b and c are shooting dumpers
a could be an active or passive shooting or other type of dumper
Ed Barker
  #44   Spotlight this post!
Unread 15-01-2009, 10:22
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
That's what all of these air propulsion system prototypes are REALLY about, ha! I came to that realization a couple of days after kickoff...nice to see someone else has it too.
But as a team we decided on a shooter, and we're not looking back this far into it.
GitHub
  #45   Spotlight this post!
Unread 15-01-2009, 10:31
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
After the no descoring rule change (design #1 scrapped), we went to a full up turret style shooter design, basically done and we all loved it. But ditched the idea after seeing all the easily broken balls (design #2 scrapped). If you think about it, each regional only has so many, and over 120 are in play each match, as the matches go on and on these balls will start coming apart and by late saturday you may be dealing with a lot of jamming. I know they won't be inspecting 120 balls between matches. It just takes 1 to jam up and end your match. Also its true a dumper needs to handle the balls also, but not nearly in such a precise way. A shooter seems risky to me, but I'm sure many will do very well with it. I can see how a shooter has the advantage if done top notch, but only within a few feet of a moving goal. I don't think pinning a trailer for a couple seconds will be that hard with a good drive system.
www.179swampthing.org
Defensive/dumper hall of fame Cody Carey Robot Showcase 80 11-03-2007 18:44
Poll: Dumper effectiveness at Championship The Lucas Championship Event 3 23-04-2006 00:33
pic: new dumper supersy77 Robot Showcase 2 11-04-2005 15:17
Ball Dumper Plans JDRobotics General Forum 6 22-01-2004 17:38
Anthropology Study Redhead Jokes General Forum 0 22-01-2004 13:56
