Go to Post Aaaah - interpersonal dynamics - the root of most problems on most teams. - UCGL_Guy [more]
Unread 14-01-2009, 16:27
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Re: Gearboxes for shooter?
well, the farther we shoot the ball, the less accuracy we have(unless we use the camera and everything) so we went for 4ft as our scoring distance, at less than 4ft it works just as well,
we're using two of these wheels bolted together(on the same shaft).... http://www.andymark.biz/08firstwheel.html
not baseball sytle, just the two wheels bolted together on some 2x4's at 8inches tall and 8 inches wide
we used the toughbox because thats all we had to get the wheel spinning fast enough(we dont have the parts for a direct drive off the cim)
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 14-01-2009, 16:50
That's what we did for Aim High, and it worked great. Should be a winner for you.
Unread 14-01-2009, 16:55
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Originally Posted by squirrel View Post
I think he could have cut and pasted from any year to get the experiment quote
IMHO - More so this year than any other. Combine a new field surface, new mandatory wheels, new restrictions on size/bumpers with a "weird" game object, and it makes for a lot to learn. Maybe our team is just slower than usual this year...
Let's be honest... it has been a long time since I'VE put any serious thought into drivetrain turning.
-John
Unread 15-01-2009, 09:39
pfreivald's Avatar
AKA: Patrick Freivald
We made some simple couplers by taking some aluminum round stock, drilling out a hole for the CIM shaft, drilling and tapping two side holes for 1/4" bolts (to squeeze the coupler onto the keyed -- or is it flat? -- part of the CIM shaft), and then threading the other end of the hole. Add some threaded rod, and ta-daa! A direct-drive coupler for the price of a few bucks and a bit of time.
Patrick
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 15-01-2009, 10:45
computerboi1503 computerboi1503 is offline
Programmer/Driver/Spokesperson
AKA: A former me.
FRC #1503 (Spartonics)
computerboi1503 will become famous soon enoughcomputerboi1503 will become famous soon enough
Although it may be a bit overkill, you could always use FP motors in a DeWALT gearbox, and just limit the output in your code. We used these on our '06 shooter, and it worked perfectly.... although we didn't limit output alot...
Unread 15-01-2009, 15:33
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
We also used two AndyMark wheels, but the 2 in. wide ones.
We tried all kinds of configurations, different motor speeds, different backspins, etc.
We came up with one big conclusion.
Unlike the Aim High game when we dealt with just simple Poof balls, these orbit balls comparably are really difficult to deal with. Too much slipping and inconsistent distances, depending on where it makes contact with the orbit ball.
Maximum distance and time that the shooter mechanism can be in contact with the ball prior to release from the robot, really improves the accuracy and grip on the ball.
I'm not going to outright come out and say it, but there is "one" robot in '06 that I think we'll see a lot of this year, much like 121 last year.
motor for ball Shooter? excel2474 Motors 42 15-01-2009 09:48
which gearboxes can we use for this year? mahmosh Kit & Additional Hardware 2 09-01-2009 19:52
Which pinions for FP motors and BaneBots 42 mm gearboxes? Madison Technical Discussion 3 23-01-2007 20:04
Speed Sensor for Ball Shooter Justin Stiltner Electrical 15 28-01-2006 14:40
