Go to Post You miss 100% of the shots you don't take - Steven Donow [more]
Unread 15-01-2009, 09:31
levp92 levp92 is offline
FRC #3089
levp92 is an unknown quantity at this point
IsAutonomous() function
When i'm trying to run this code the program it's working:
#include <iostream.h>
#include "math.h"
#include "AxisCamera.h"
#include "BaeUtilities.h"
#include "FrcError.h"
#include "TrackAPI.h"
#include "WPILib.h"
class robot1 : public IterativeRobot
public:
	TrackingThreshold td;
	ParticleAnalysisReport par;
	ColorReport cReport;
	robot1(void)
		td = GetTrackingData(RED, FLUORESCENT);
		printf("auto5\n");
		if (StartCameraTask(20, 0, k160x120, ROT_0) == -1) {
			printf("Failed to spawn camera task; exiting. Error code %s\n",
					GetVisionErrorText(GetLastVisionError()) );
		printf("auto5\n");
	void AutonomousContinuous(void){
			IsAutonomous();
			if ( FindColor(IMAQ_HSL, &td.hue, &td.saturation, &td.luminance, &par, &cReport) ){
				printf ("**  found: Servo: x: %f  y: %f \n", par.center_mass_x_normalized,	par.center_mass_y_normalized);
START_ROBOT_CLASS(robot1);
but if I run this code the program it's working:
#include "math.h"
#include "WPILib.h"
public:
	robot1(void)
		printf("auto5\n");
		printf("auto5\n");
can somebody please explain me why?
Unread 15-01-2009, 09:41
popnbrown's Avatar
popnbrown popnbrown is offline
FIRST 5125 HOTH Lead Mentor
AKA: Sravan S
FRC #5125 (Hawks on the Horizon)
popnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond repute
Re: IsAutonomous() function
My first guess would be that "IsAutonomous()" asks the robot if it is still in the autonomous status. Can you tell me what the status of the driver station is? If you are even connected?
I'll get back to you, after double checking the WPILib documentation. But it might be a little bit, so here is my advice. Figure out what IsAutonomous() does.
My guess is that it looks at the driver station and if it driver station is enabled and in autonomous mode, then the IsAutonomous() will continue and if the driver station is not in autnomous then IsAutonomous() breaks the loop in which it is called.
Check the WPILib documentation, there should be something about IsAutonomous() in there.
Good Luck,
Sravan
I am an employee of FIRST. However, the postings on this site are of my own perspective as a FIRST mentor and volunteer and do not necessarily reflect the views of FIRST.
FIRST Team 5125 Hawks on the Horizon Lead Mentor
FRC Team 4096 Ctrl-Z Former Mentor
FTC Team 5203 #19@! Former Mentor
FRC Team 1403 Cougar Robotics Alumni
Unread 15-01-2009, 10:16
Jared Russell's Avatar
Taking a year (mostly) off
I think that this is because calling IsAutonomous() on every pass through the continuous code causes the print buffer to be flushed.
Try calling the function "fflush()" (no arguments) after your printf() statement without calling IsAutonomous().
As an aside, you probably won't want to print in the XXXContinuous() functions. It will go so fast you won't be able to read it. The XXXPeriodic() functions might be a better fit here.
Unread 15-01-2009, 10:57
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
As to why your first code block isn't working, I can't say exactly. Looking at the code, IsAutonomous gets data from the driver station and returns the value of the autonomous member. Maybe there's an issue with getting data in the continuous loop?
Additionally, with an IterativeRobot,you don't need to explicitly call IsAutonomous since your AutonomousPeriodic and AutonomousTeleop will only be called when the mode is autonomous (check out IterativeRobot::StartCompetition)
else if (IsAutonomous())
			// call AutonomousInit() if we are now just entering autonomous mode from
			// either a different mode or from power-on
			if(!m_autonomousInitialized)
				// KBS NOTE:  old code reset all PWMs and relays to "safe values"
				// whenever entering autonomous mode, before calling
				// "Autonomous_Init()"
				AutonomousInit();
				m_autonomousInitialized = true;
				// reset the initialization flags for the other modes
				m_disabledInitialized = false;
				m_teleopInitialized = false;
				printf("Autonomous_Init() completed\n");
			if (NextPeriodReady())
				AutonomousPeriodic();
			AutonomousContinuous();
Also, just so you're aware in case you or someone else needs it, IsAutonomous returns a boolean telling if the state is autonomous or not. Simply calling it like you did in your first code block won't actually do anything since the return value is ignored. If you want to use it to make a decision you would need to put it in an IF statement (for example) as is done in the code block that I posted.
Unread 15-01-2009, 11:00
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
From the doxygen output:
bool RobotBase::IsAutonomous ( void )
Determine if the robot is currently in Autnomous mode.
Returns:
True if the robot is currently operating Autonomously as determined by the field controls.
So what you're doing there is asking if you're in autonomous mode inside of your autonomous loop, and then doing nothing with that information!
When using an iterative robot, you don't need to call IsAutonomous() - the loop will only run while you are in autonomous, and will stop when you aren't. If you're running a simple robot (with no build in looping structure, you'll want to put something similar to:
void Autonomous(void)
    while(IsAutonomous())
        //do your autonomous stuff
        watchdog.feed();
Unread 15-01-2009, 11:12
That brings up a good point. I don't see you doing anything with the watchdog. Unless you a) set the expiration to something manageable and b) feed the watchdog regularly, you have the potential of running into major problems with the cRIO resetting on you. Once you get into this scenario, it will be hard to fix depending on where the problem is because you will have a link to the driver station for just a few seconds before it resets again.
I would highly suggest adding this to your robot1 constructor
GetWatchdog().SetExpiration(100);
and this to the top every function that you're overriding from IterativeRobot (i.e. AutonomousContinuous)
GetWatchdog().Feed();
Unread 15-01-2009, 11:34
        watchdog.feed();
I think what he was trying to say (sorry if I get this wrong) is that his code works if he calls IsAutonomous(), but doesn't if he doesn't.
As I said in my previous response, I think that this is an issue with the stdout buffer not getting flushed.
Unread 15-01-2009, 13:12
danielg30 danielg30 is offline
FRC #3089
danielg30 is an unknown quantity at this point
Hi!
I'm a programming mentor from lev's team, we are trying to get an iterative robot camera example up and running, the DS is OK and configured properlly but still no success
we have discoverd that the "isAutonomos()" line is present everthing works fine, and nothing otherwise, any ideas why?
(i would appriciate if someone can upload here a simple IterativeRobot camera color tracking example)
thanks
daniel
Looping a function Tz0m Programming 14 20-02-2007 11:22
Scoring function in C mgreene Programming 7 12-01-2007 02:36
Arcade Function gabrielse Programming 1 08-02-2006 00:49
Limit_Mix() Function EricWilliams Programming 2 27-07-2005 23:19
FreeLibrary() Function Raven_Writer Programming 0 09-08-2003 15:39
