Go to Post I don't know, there's quite a few teams that apply to travel to some random HS gym in Indiana every summer. - GaryVoshol [more]
Unread 15-01-2009, 12:03
Killraine Killraine is offline
Team Robot
AKA: Josh Lucas
FRC #2016 (Mighty Monkey Wrenches)
Killraine will become famous soon enoughKillraine will become famous soon enough
HS-475HB Servo
The Rules allow for an "C. An unlimited number of FIRST Tech Challenge (FTC) servos (HITEC HS-475HB servos)."
On the website, Servocity offers a stock 90 degree rotation for the servos and also a 180 degree and continuous rotation option. I called them to see how this is accomplished, and they told me that resistors are added to change the available rotation.
My question is would these be legal under the rules? I'm afraid that this might count as "modification" or not be concurrent with the FTC servos intention.
Thanks.
Unread 15-01-2009, 12:09
Re: HS-475HB Servo
Thanks.
You could also use <R51>B, which allows "An unlimited number of COTS servos with a maximum output torque of 55 oz-in and
maximum rotational speed of 100 rpm at 6 Vdc (e.g. HITEC model HS-322HD or HS-325HB servos, as provided in the Kit Of Parts),"
I am sure of this, however: if you use a servo with a different part number than the FTC ones in <R51>C, it had better meet the specs in <R51>B!
I'm not sure if having the rotation shortened is legal, but Q&A can tell you. It is a stock configuration, but still...
Unread 15-01-2009, 13:24
Team Robot
AKA: Josh Lucas
Re: HS-475HB Servo
Haha, it seems you are looking at this in the same kind of way I am. They are both listed as "HS-475HB Servo" when I go to order from ServoCity, but they do have different product numbers. I don't know if this is considered lawyering of the rules, but it seems that this is allowed. IMO spirit of the rules is to prevent teams from using something like this.
Unread 15-01-2009, 13:36
Re: HS-475HB Servo
Just to be on the safe side, Q&A it. I would suspect it would be legal to use any of the three rotations, but you never know. (And, under which part of the rule, B or C.)
Unread 25-01-2009, 23:50
JCharlton's Avatar
Happy Birthday! JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Re: HS-475HB Servo
I'm also very interested in hearing the answer to this!
It's a key element of our design, and I just started wondering if it would violate any of the rules about motor or signal mods. Ouch.
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 25-01-2009, 23:58
Re: HS-475HB Servo
The question has already been asked.
http://forums.usfirst.org/showthread.php?t=11379
So a standard servo that has a limited rotation (or not) is allowed provided that it doesn't violate <R51-B>.
Unread 26-01-2009, 00:08
JCharlton's Avatar
AKA: JC
Re: HS-475HB Servo
Ah! You don't find that searching for "servo", but you do searching for "servos".
I'd still like to get a definitive answer on hacking the servo's internal resistor (which is what the servocity kit does) since it is so integral to our design. Better do it now than in the pits. I'll post a question in the morning after a night's sleep.
Thanks,
jc
Unread 26-01-2009, 00:11
Re: HS-475HB Servo
Thanks,
jc
I would say that if you do the mod yourself, you're on questionable ground; <R53> bans modifications. However, this is available as a stock configuration. What I would do is go ahead and ask if you can do it yourself. If you can, go for it. If not, get a stock servo with the rotation you're looking for.
Servo Specs Killraine Motors 3 09-01-2009 15:13
Servo Help Newzealand38 Programming 10 13-01-2008 23:14
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
Camera Servo Obi Programming 2 30-01-2005 17:09
Servo MASherry General Forum 6 04-10-2004 22:46
