Go to Post I can neither confirm nor deny that I've worked on alot of pretty cool stuff. - Gary Dillard [more]
Unread 15-01-2009, 13:13
brianafischer brianafischer is offline
FRC #0503 (Frog Force)
brianafischer is on a distinguished road
Re: jaguar brake\coast controlling
Originally Posted by s1900ahon View Post
Per <R60> if you want to wire the Brake/Coast Jaguar input, you must do so directly to the Digital I/O of the DSC. In this case, you should use a SINGLE wire between the signal of the DSC and the middle pin of the CB header (and only a single wire). To connect any other wire invites shorting unequal voltage sources or introducing additional current return paths.
To clarify this:
Using a DMM, our team checked the ground path between the Digital Sidecar ground and the Jaguar Brake/Coast Header ground. There was an open circuit (MOhm reading). We tested the Jaguar with a single connection which resulted in the DOUT OFF (0V/coast) state not working. Thus, we added a pull-down resistor (as stated in the spec sheet for the Jaguar) referenced to the GND pin of the Digital Sidecar.
2 wires on the digital sidecar, 1 wire to the jaguar.
Victor Brake/Coast Default FRC4ME Electrical 7 31-03-2008 13:40
Brake / Coast switching for Victors nreyesciena Control System 2 28-01-2008 13:17
Victor 884 Brake/Coast Issues sciguy125 Control System 23 23-01-2005 14:46
Speed Controller brake/coast setting steven114 Electrical 21 03-03-2004 13:05
Brake/Coast Jumper archiver 2001 3 24-06-2002 01:04
