Go to Post However, do not confuse faith in your ability to overcome challenging obstacles, with the difficulty of the obstacles themselves. - Joe G. [more]
Unread 15-01-2009, 13:25
vamfun vamfun is offline
Mentor :Contol System Engineer
AKA: Chris
FRC #0599 (Robodox)
vamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of light
Send a message via AIM to vamfun
Cantilever Wheel Bumpers
"Under the provisions of Rule <R08-M>, the entire length of the BUMPER must be structurally backed by the frame of the ROBOT. Standoffs, stanchions, and spacers used to mount the BUMPERS that result in lengths of the BUMPERS being unsupported will be considered a violation of this rule."
We plan to place aluminum structural plate (say 1/8in) across the Standoffs so to meet the intent of this rule. The plate will be bolted to the frame with pillow blocks. The plate is removable to get access to the wheels.
Does anyone see a R08 violation with this?
Unread 15-01-2009, 13:30
Re: Cantilever Wheel Bumpers
I don't, but it never hurts to make sure.
I'd phrase a Q&A question similarly to: "Would structural material running the length or width of a bumper attached to the bumper side of a set of standoffs meet the intent of <R08> if it was removable separately from the bumpers?" (This to cover other similar tricks.)
Unread 15-01-2009, 13:33
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Calling it structural doesn't make it structural.
1/8 aluminum is pretty thin, and I doubt you'll actually be relying on it for any structural support for the robot - especially not in a single thin strip.
Definitely Q&A this, because as I see it, if you had a judge that understands robot design, they'd take one look at that 1/8 inch thick strip of aluminum and tell you it doesn't meet the rule.
Unread 15-01-2009, 13:43
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
This rule was a major cause of our decision to go with non-cantilevered dead axles this year. It turns out to have saved us some time and work, too. Plus we have a nice mounting surface (the robot chassis) at the perimeter of the robot to mount our roundish ball handling mechanism.
Unread 15-01-2009, 13:44
Jared Russell's Avatar
Taking a year (mostly) off
Good Q&A question.
The wall thickness of the kit frame is only 1/8", so I think that this should suffice (granted the kit frame is C channel).
Unread 15-01-2009, 13:45
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
"roundish ball handling mechanism". I like that.
Hi!
Unread 15-01-2009, 13:49
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Unfortunately, the inspectors are not typically qualified to determine what may or may not be a structural member. A plate, no matter how thin, will in some manner affect a frame's rigidity and strength.
Who is the ultimate arbiter of "structure" and of what represents sufficient contribution to the durability of other structures?
--Madison--
...down at the Ozdust!
Where can I sign up?
Unread 15-01-2009, 13:54
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I agree.
To stay in compliance with this rule we're using 1/8" thick honeycombed fiberglass plates, and the gaps themselves are relatively small (7" max). We know that this is structurally sound, but to the typical person "that stuff is too thin".
GitHub
Unread 15-01-2009, 14:31
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Ultimately, the teams will probably have the final say in whether something counts as structural support for a bumper. But I think everyone should note the GDC's caution that they implemented this because unsupported bumpers were breaking or splintering under impacts. So teams should probably expect to get away with "structure" that doesn't look too incredibly flimsy.. But they should also expect bumpers to be closely examined for damage and for robots with damaged bumpers to be banned from the field until the problem is fixed.
Unread 15-01-2009, 14:59
CraigHickman
Posts: n/a
Sure it does.
Anyone see the plastic coverings on the sides of 254 for 06, the last year before bumpers were required? I recall them only using some (fairly) thin polycarb, and they were fine....
Unread 15-01-2009, 15:22
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Lets all not forget that the most sound structure on the perimeter is the bumper themselves. Adding an additional thin sheet as the backing is bonus.
I have yet to see a bumper break completely in half due to impact.
If it happened, I bet rarely.
Mandatory bumpers (in how they should be made and mounted) in itself should be self-sufficient. If not, why make them required (considering the purpose is to protect robots)?
If the new rule implies that the bumper themselves may not hold up during a competition, then the rules for how to make them should be modified to meet its objectives in any situation.
Unread 15-01-2009, 17:20
qwertyuiop[]\'s Avatar
qwertyuiop[]\ qwertyuiop[]\ is offline
Drive Train/Manipulator Team Leader
AKA: Steven Harris
FRC #0623 (Cougar Robotics)
qwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of light
Does the back have to be completely covered? we are planning just to bolt our bumpers on to the second layer of our 8020 frame.
_________________ second layer
|_______|________| first layer
"...i told you i wanted the left-handed screwdriver not the right-handed one..." always let the mentors get their morning coffee or else they start getting angry and making stuff up.
2005 NASA VCU Website Excellence Award, 2006 NASA VCU Website Excellence Award, 2006 Capital Clash, 2006 Delaware FVC Regional, 2007 Ramp Riot, 2007 Virginia FTC Regional, 2008 NASA VCU Regional, 2008 Battle of Baltimore, 2008 Virgina FTC Regional
Unread 15-01-2009, 17:57
You should be fine. If you really want to be sure, ask Q&A.
<R08> M says length, not height or back. If they had wanted the entire back covered, they would probably have said so.
Unread 15-01-2009, 20:00
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
From a related thread:
Originally Posted by dlavery View Post
I hate to "break" it to you, ...
I highly recommend reading Dave's full comments on this topic, in the thread linked above.
Richard Wallace
since 2003
3 wheel vs 4 wheel omni bear24rw Technical Discussion 2 18-05-2008 08:56
bumpers bensamra34 Rules/Strategy 1 18-01-2008 22:38
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
2-wheel versus 4-wheel drive Ben Mitchell Technical Discussion 23 07-11-2003 00:50
