Go to Post I'd love to see a simple, robust system that connects quickly and dependably. - Andy Baker [more]
  #106   Spotlight this post!
Unread 15-01-2009, 14:25
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: 4WD Turning Difficulties
In addition to the CoF values, where is your CG at? Moving it rearward helps your turning significantly.
Mark
Brick walls are for other people. - Randy Pausch
  #107   Spotlight this post!
Unread 15-01-2009, 17:12
Best Available Data
FRC #1778 (Chill Out!)
Originally Posted by Brandon Holley View Post
If you have not hooked up a trailer to your robot, do it.
It may seem optimistic when you are driving just the robot, but as Paul said, it is just PAINFUL to drive with the trailer on.
Really? We've had a different experience. I find driving with the trailer is more enjoyable. Sure, there is a slight loss of control at first, but once you get the hang of it you can pull some really nifty tricks. That said, you need a pretty big practice area to get the hang of driving the thing. From a dead stop, driving really slowly we can barely make an about face on two sheets (with the trailer on).
IR Difficulties AmitCarmeli Programming 3 11-01-2008 20:49
Technical Difficulties muy dificil Programming 0 13-10-2005 11:25
Default Code Difficulties Drok00 Programming 3 02-02-2005 20:56
FIRST Technical Difficulties at Rutgers aka Scott White General Forum 10 27-03-2002 14:40
