Go to Post I'm sure I'm not the only one that feels like a blind man in a room full of sharp objects when it comes to programing. - Protronie [more]
Unread 15-01-2009, 17:34
spc295 spc295 is offline
FRC #0295 (Renevatio)
spc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to behold
<R06>
with all this ruling on behalf of the GDC I guess we ore not even allowed to pick up moonrocks anymore, because that would increase the normal force. by carrying balls in a hopper you will increase your normal force. Also does that mean a shooter is out since accelerating a ball up will also increase your normal force?
295 Team Captain
Unread 15-01-2009, 17:45
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
Re: <R06>
I think your reading into it too much. The GDC understands that some actions during the normal playing of the game will increase your weight and traction at various points IE Picking up Moon Rocks.
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
Unread 15-01-2009, 21:56
JackG's Avatar
JackG JackG is offline
Internet is a series of ubertubes?
FRC #0001 (Juggernauts)
JackG is a splendid one to beholdJackG is a splendid one to beholdJackG is a splendid one to beholdJackG is a splendid one to beholdJackG is a splendid one to beholdJackG is a splendid one to beholdJackG is a splendid one to behold
Re: <R06>
Let me quote <R06> so that we have some reference here.
ROBOTs must use ROVER WHEELS (as supplied in the 2009 Kit Of Parts and/or their
equivalent as provided by the supplying vendor) to provide traction between the ROBOT and
the ARENA. Any number of ROVER WHEELS may be used. The ROVER WHEELS must
be used in a “normal” orientation (i.e. with the tread of the wheel in contact with the ground,
with the axis of rotation parallel to the ground and penetrating the wheel hub). No other
forms of traction devices (wheels, tracks, legs, or other devices intended to provide traction)
are permitted. The surface tread of the ROVER WHEELS may not be modified except
through normal wear-and-tear. Specifically, the addition of cleats, studs, carved treads,
alterations to the wheel profile, high-traction surface treatments, adhesive coatings, abrasive
materials, and/or other attachments are prohibited. The intent of this rule is that the ROVER
WHEELS be used in as close to their “out of the box” condition as possible, to provide the
intended low-friction dynamic performance during the game
This rule says nothing about normal force, gravity, or anything like that. The only time normal force was mentioned (at least so far and to my knowledge) was on Bill's blog. He discouraged teams from making devices specifically designed for increasing normal force. I'm sure the GDC is reasonable enough to realise that increasing normal force may be a byproduct of certain robot actions and thus would not outlaw them.
Unread 15-01-2009, 22:01
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: <R06>
I think the concern of the OP probably resulted from reading the answers to these two questions:
http://forums.usfirst.org/showthread.php?t=11025
Originally Posted by GDC
No. Any vacuum/suction/fan system that alters the traction characteristics of the ROBOT would be considered a violation of Rule <R06>.
http://forums.usfirst.org/showthread.php?t=11225
<R06> would preclude mass manipulation as a traction aid.
Unread 15-01-2009, 22:03
Re: <R06>
Correct. People have asked using the term, but the GDC uses terms like "increased traction". The rule is NOT "you can't increase your normal force", but "you can't increase your traction". Devices specifically intended for that purpose have all been outlawed already. Devices that help accomplish a game objective (namely scoring) are apparently not an issue.
Even non-tractive wheels (i.e. within a small percentage of the rover wheels) are allowed for purposes of data gathering only.
Unread 16-01-2009, 12:43
Re: <R06>
could the GDC rule that your maximum wieght be 120lbs, when you are full or moon rocks. for example if we weighed 119lbs, off the field then could we only pick up a certain number of moon rocks so that we would never be more then 120lbs. (not including bumpers and batteries) then a lighter robot say 115lbs could pick up more then the heavier robot? or does the maximum volume deminsions not include the weight of your payload. I am asking this becase of the recent ruling about the net bieng used to hold the orbit balls.
295 Team Captain
Unread 16-01-2009, 12:58
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: <R06>
The response regarding the net dealt specifically with it exceeding the dimensional envelope as a result of it containing orbit balls. It had little to do with the act of storing balls itself.
--Madison--
...down at the Ozdust!
Unread 16-01-2009, 14:05
CraigHickman
Posts: n/a
Re: <R06>
Unless you decide to make the balls part of your robot, they're considered field objects, and not robot components.
Unread 16-01-2009, 14:41
Re: <R06>
Other than the fabrication timeframes, the GDC doesn't normally write unenforceable rules. This one would be difficult at best to enforce, if not outright impossible.
That and the game pieces aren't robot parts.
Unread 20-01-2009, 11:40
hdanak hdanak is offline
FRC #2584 (Reseda Regents Robotics)
hdanak is an unknown quantity at this point
Re: <R06>
I don't quite understand the big deal about making the robot heavier... while an increased normal force may improve traction, it won't help accelerating and braking-- if your robot is heavier, it is that much harder to accelerate. I suppose the only advantage is if another robot were to push you, then it would take a larger force to break static friction. I think that the only reason it seems to improve acceleration is that it slows down the motor speed, bringing it below the threshold of breaking static friction (g*u_s). On the other hand, using idler wheels for the purpose of getting robot motion data may waste the weight that it would have driven otherwise... the other wheels must still pull that load.
Hike Danakian, Reseda Regents Robotics (2584)
Unread 20-01-2009, 11:43
Jared Russell's Avatar
Taking a year (mostly) off
Re: <R06>
Increasing robot mass increases the percentage of the robot/trailer system that is applying power to the floor, thereby increasing maximum acceleration and deceleration.
In other words:
F = u*N = u*m*g
F = m*a
The "m" in the top line does not include the mass of the trailer.
The "m" in the second line does
Unread 20-01-2009, 11:45
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: <R06>
The big deal about making the robot heavier, is that you have to accelerate the mass of the robot AND trailer, but you only have the tractive force of the robot wheels to do it. The higher the percentage of total weight that's on the robot wheels, the higher your acceleration can be.
Unread 20-01-2009, 13:11
Re: <R06>
Incidentally, the GDC has clarified that "normal" actions such as handling the orbit balls are perfectly legal even though they increase the normal force slightly, while actions intended purely to increase the normal force are illegal.
http://forums.usfirst.org/showthread.php?t=11275
Unread 20-01-2009, 13:33
Gazelleman's Avatar
Gazelleman Gazelleman is offline
AKA: Brad Sperry
FRC #0135 (Black Knights)
Team Role: Student
Gazelleman is an unknown quantity at this point
Re: <R06>
I think all that FIRST is saying is they don't want people intentionally trying to gain force or traction. The point of the game is to score points in trailers without much traction, not to figure out how to get more traction so you can score more points.
Unread 20-01-2009, 14:18
ScottOliveira ScottOliveira is offline
FRC #3455 (Carpe Robotum)
ScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really nice
Re: <R06>
The maximum VOLUME dimensions do not include the WEIGHT of your payload.
The ruling with the net occurred because the net could expand beyond the maximum volume dimensions of the robot, not because of any added weight concerns.
<R06> normal wear and tear Darkcrosbone Rules/Strategy 54 27-01-2009 18:03
R06 Questions SamM Technical Discussion 3 16-01-2009 14:50
R06 clarification Bruceb Rules/Strategy 6 06-01-2009 17:13
R06 - weight and configuration jimfortytwo Technical Discussion 6 18-02-2004 08:06
Rule <R06> Jack Technical Discussion 18 11-01-2004 13:36
