Go to Post Yes, I try to win matches, but you don't want to disrespect opponents......just get on their nerves an awful lot! :D - Josh Goodman [more]
Unread 15-01-2009, 17:42
SamRI SamRI is offline
FRC #2443
SamRI is an unknown quantity at this point
Two Joysticks
How do program to use two joysticks in LabView
Unread 15-01-2009, 18:17
TotalChaos's Avatar
TotalChaos TotalChaos is offline
AKA: Austin
FRC #2837 (Freebird Robotics)
TotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud of
Send a message via MSN to TotalChaos
Re: Two Joysticks
Hi SamRI,
If you're using the basic framework, here's one way:
Select the Open VI that already exists. (Along with the constant)
Hold Ctrl and click and drag the selection to make a copy of them. Place it right below the other and change the constant to "USB 2" ... or whatever port you're using.
Wire it up just like the other one
And then lastly (don't forget this) be sure to close it out. On the other side of the loop select the Close VI and copy it just like you did with the Open VI
And then just wire it up
I hope that answers your question.
Good luck!
- Austin
The 39th Aero Squadron - Team 39! (Visit our website!)
Team Role: 3 Years as Driver - College Student/Mentor!
Freebird Robotics - On a 1 year hiatus! (Visit our website!)
Arizona 2009: Semifinalists! (69 and 498), Delphi "Driving Tomorrow's Technology" Award
Unread 15-01-2009, 18:21
FRC #2443
Re: Two Joysticks
Thanks for the help
But We are using the Advanced settings because the Basic Setting didnt work on our bot
Controlling a Mecanum drive with two joysticks? Leav Technical Discussion 9 09-12-2007 19:11
two joysticks TEAM 1436 Control System 14 03-03-2005 21:23
AVB joysticks..and other analogue joysticks tml240 Kit & Additional Hardware 6 07-02-2004 12:45
Two Right Joysticks??? Evil_Warlord_42 Control System 26 28-01-2004 23:59
Putting two and two together... Andy Grady General Forum 13 08-01-2004 18:29
