Go to Post Our team is using a video camera with frame-by-frame analysis to figure out all the characteristics of the foam ball. If the Boeing engineer says it's possible, I'm going to believe him. - sciencenerd [more]
  #31   Spotlight this post!
Unread 13-01-2009, 21:46
ScottOliveira ScottOliveira is offline
FRC #3455 (Carpe Robotum)
ScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really nice
Re: No-show teams and trailers
It seems like it would be fairly easy to detach the tongue from the trailer, it's only held in by a few easily accessible bolts (at least that's how it appears in the provided technical drawings.
I think the best solution would be to detach the tongue and attach a caster to keep the platform upright.
  #32   Spotlight this post!
Unread 13-01-2009, 22:17
Best Available Data
FRC #1778 (Chill Out!)
Originally Posted by Rick Wagner View Post
I want to verify I haven't missed something, but after the third update, there still seems to be no Q&A response or rules update that addresses this issue. The trailer tongue for a no-show robot will gouge the regolith when it gets shoved out of range of an opposing PS by an alliance partner. The trailer will also rest at a non-vertical angle, and might be tipped over backward fairly easily.
I would have posted my own Q&A question on this, but someone earlier in the thread said he would ask.
If you look at FIRST's field drawings the trailer hitch is pretty different than the one in the team drawings. The end of the rod is a hemisphere, so I highly doubt it will scratch the regolith. (Sorry, I can't remember the exact drawing number! It's in there though!)
  #33   Spotlight this post!
Unread 15-01-2009, 15:00
Rick Wagner's Avatar
Rick Wagner Rick Wagner is offline
FRC #3008 (Kalani Robotics)
Rick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to behold
It will be interesting to see if the answer comes tomorrow on Q&A. Even if the tongue has no sharp edges, robots can run up on it or in a worst case scenario, the trailer gets tilted back for a second and a robot gets impaled on the tongue. The suggestion above, to remove the tongue for safety, seems to me to be workable. Removing the entire trailer, as has been pointed out, is apparently unworkable from a game dynamics viewpoint.
Perhaps the best solution, ultimately, will be to introduce a special tongueless trailer with a third wheel (no caster necessary, I think), just for the case of no-show robots. That means building extra trailers or modifying existing ones in realtime during the competitions.
  #34   Spotlight this post!
Unread 15-01-2009, 15:02
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
I suspect that we will just see surrogate robots playing for any robot that does not show.
___________________
- Tennyson, Ulysses
  #35   Spotlight this post!
Unread 15-01-2009, 15:05
I wonder if the surrogate robots will have autonomous modes and what they will be.
  #36   Spotlight this post!
Unread 15-01-2009, 15:07
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Surrogates are usually nothing more then a stand in team (without the penalty issue of <G14>)
___________________
- Tennyson, Ulysses
  #37   Spotlight this post!
Unread 15-01-2009, 15:12
That could work. Would the no-show team still play their payload specialist? I suppose so.
  #38   Spotlight this post!
Unread 15-01-2009, 15:20
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Yup. Full team. Just would not get the ranking points or W/L record.
___________________
- Tennyson, Ulysses
  #39   Spotlight this post!
Unread 15-01-2009, 15:23
I don't know about having surrogate teams (outside of the normal ones). It's kind of like, "Hey could you guys fill in for team XXXX right away?" You're really going to irritate some people.
I also don't see this being too much of an issue. 90% of matches have two full alliances. The other 10% are mainly due to broken robots. Stick the robot onto the field, get it away from its launch pad, and disable it or drive around doing nothing.
  #40   Spotlight this post!
Unread 15-01-2009, 15:33
There is generally a fair number of teams willing to be a surrogate alliance member, just to get a little more practice and a little more exposure.
  #41   Spotlight this post!
Unread 15-01-2009, 15:40
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
There is also one very harried person in charge of team queuing at each event. If you told this person that they'd have to hunt down a surrogate team for every no show, in addition to hunting down the no-show, they probably wouldn't like you much.
Not to mention how it would screw up the scoring software, or the team/match list for the MC, or....
It's just not going to happen. There's far too many difficulties involved compared to just leaving a trailer out there.
  #42   Spotlight this post!
Unread 15-01-2009, 15:41
And they've never been used. Ever. Except in the official surrogate matches or as a backup in the eliminations. (OK, and in practice matches.)
  #43   Spotlight this post!
Unread 15-01-2009, 15:43
Leaving the no-show robot's trailer out there would have two benefits: first, it would emphasize the importance of getting your robot ready on time. Second, it will lead to some interesting autonomous modes and driver team play in "rescuing" the lonely trailer from its starting position.
  #44   Spotlight this post!
Unread 15-01-2009, 19:10
GaryVoshol's Avatar
Cogito ergo arbitro
Beside being a queuing nightmare, how are you going to regulate it? "Brokenbot from team 9999 can't play, can we get a surrogate? OK, Pink will do it." Yeah, that'll go over well with the opponents.
The other 10% are mainly due to broken robots. Stick the robot onto the field, ...
At least two problems with this. First, you pull the broken robot out of its pit for 20 minutes or so, making it less likely it would get fixed for the following match. Second, a broken robot hurredly patched back together to sit on the field could be an illegal robot (they forgot to include something). Now Brokenbot has just caused their alliance a penalty, and maybe a yellow card (see <S04>).
(since 2004)
  #45   Spotlight this post!
Unread 20-01-2009, 19:15
Update 5 is out today but this issue is still not addressed.
Weight of Trailers vivek16 General Forum 23 17-01-2009 17:02
2 teams featured on super's tv show mysonwearspink FIRST In the News... 0 07-08-2007 11:08
Animation teams needed to show their animations rrockafellow 3D Animation and Competition 2 12-05-2004 09:42
the FSK show (fork, spoon and knife show) Psalms(118:6) Rumor Mill 0 23-04-2004 08:33
2 FIRST teams to be on the Donny and Marie Show archiver 1999 1 23-06-2002 22:31
