Go to Post There is no offseason. - Jeff Rodriguez [more]
Unread 15-01-2009, 20:19
Phoenix Spud's Avatar
Phoenix Spud Phoenix Spud is offline
Everyone. Everywhere.
FRC #3132 (Thunder Down Under)
Phoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond repute
WPI gyro code question
We hooked up the gyro (yeah!!!) and used WPI's sample code. We found that thatthe gyro that came in the KOP does not work with WPI's library. It will give you half (apx.) of the correct value. We hooked up an old gyro and found that it actually worked. Next we doubled the value of SetSensitivity, we thought that this would fix the problem. What it actually did is halved the number we were getting. This made our reading 1/4 of what it actually should be. We looked at the library more and realized that the library was using the reciprocal of the number we were supplying to SetSensitivity. So we gave it half of the original number. Although this was closer to the actual reading, it still was not exact. Our best guess is that WPI made the gyro class with the old gyro, hence why our old gyro worked. Has anyone else found this problem, or the fix? Or do you know if WPI plans to put out a fix for this?
Sarah Heimlich
Outreach Mentor | Business Mentor
FIRST® TEAM 3132
Unread 15-01-2009, 21:00
Re: WPI gyro code question
Don't forget to read the sensor manual!
The WPIlib gyro/accelerometer code was written before we knew what this year's sensors would be. It still works, you just need to wire in new constants, which are found in that manual.
Unread 15-01-2009, 21:03
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
It looks like they have the default Volts per degree per second as .0125 and this year's sensor is 7mV per degree per second It should be in the sensor manual. Try .007 as sensitivity?
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 17-01-2009, 09:14
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
0.007 is what we are using. Now we just have to connect the temperature output to compensate for the error... (which, the error is *really* low)
WPI camera code error Phoenix Spud C/C++ 3 15-01-2009 17:44
WPI Lib Source Code from subversion at WPI Sourceforge steinra Programming 6 02-12-2008 16:34
Gyro Code Problems railerobotics Programming 8 27-01-2006 10:45
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
gyro code odin892 Programming 2 08-04-2003 14:50
