Go to Post Amazing what you can find with a quick video and the unlimited power of the internet! - AveryLevin. [more]
Unread 15-01-2009, 20:23
Re: A List of Problems
Everything's powered up - DS, cRIO?
Everything's connected?
Your PC to the DS ETH2 port
The DS ETH1 port to the cRIO port 1
Your PC is set to an IP of 10.24.29.6
and subnet mask of 255.0.0.0
Firewalls need to be turned off on your PC.
If you have a network card that should be turned off too.
There are a bunch of PC things that block or obstruct network access.
Unread 20-01-2009, 00:31
ExarKun666's Avatar
ExarKun666 ExarKun666 is offline
Ben Error/MC Ben/NC Ben
AKA: Ben Kellogg
FRC #2429 (LCEC)
ExarKun666 is an unknown quantity at this point
Send a message via AIM to ExarKun666 Send a message via MSN to ExarKun666 Send a message via Yahoo to ExarKun666
Okay update of both cRIO, and DS is officially over with, yeah!
But now 1 more problem, I hope, and then I think we are good, I realized when I tried to download code, the code didn't go on. To test this theory I flipped the autonomous switch, and the supposed prewritten autonomous didn't run, so I know 100% it's with the target or something, so do you have to set the target, how, and where to? Anything else we should know for downloading code?? TY for the help
Ben Kellogg
Team Sites: [LCEC Site] [FRC/FLL Site] [LCEC Blog]
Unread 20-01-2009, 10:06
It depends first on what code you started with:
-- LabVIEW Basic or Advanced or one of the examples?
-- Wind River template or example?
When you switch to autonomous does the status light on the Digital Sidecar start to blink by any chance?
If you're using a LabVIEW Basic/Advanced Framework then you set your Target IP when you first create your project. If you forgot to then you'll see it in the Project Explorer as:
"RT CompactRIO Target (10.xx.yy.2)"
Unread 20-01-2009, 19:04
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
Okay we are using WindRiver, example, not template.
So I see on the top bar there is a target option, so I'm not sure what to do... can you help us?
Ben Kellogg
Unread 21-01-2009, 09:38
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
Anyone know how to set the target, using Wind River example?
Ben Kellogg
Unread 21-01-2009, 10:19
Take a look at the C Programming Guide for FRC.pdf to see if that helps you.
It's located on your laptop at: C:\WindRiver\docs\extensions\FRC
Starting on page 13 it describes how to setup the environment and download a program.
An updated copy was installed with the latest Wind River update (http://www.usfirst.org/frccontrolsystem ).
One of the things you need to do is to go to Windows on the top menu bar and select Preferences.
Under Preferences you'll see "FIRST Downloader Preferences" and in there you need to set your team number, and find the ".out" file that your example generates. You can locate it by drilling down through your project files in the Wind River Project Explorer in the upper left window.
The .out will be under whatever project directory you've made. Mine happens to be C:\WindRiver\2009. For instance, I have a Simple Template project and the .out is buried under: C:\WindRiver\2009\SimpleTemplate\PPC603gnu\SimpleT emplate\debug\SimpleTemplate.out
Which of the examples are you using? An FRC one or one of the others that runs a generic C++ program on your PC?
Unread 21-01-2009, 10:47
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
we are using an FRC template.
Ben Kellogg
Unread 23-01-2009, 00:34
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
We have a problem.
Okay, when I saw the problem I went through and made sure everything was connected, everything powered, the dongle in enabled, ect...
The problem is that when we turn on everything, with the DS on and tethered to the cRIO, the victor884s blink the orange light, yes the DS is enabled, and yes we have updated the firmware on the DS, and re-imaged the cRIO, and updated LabView on our comp, and set up the wireless bridge even. The PWM cables are in 1 & 2, ethernet in port 1 to port 1, ect... I was going to call FIRST tech service, but I wanted to come here, see if there were any suggestions on what might be wrong so if anyone can lend a suggestion to what the problem may be, please let us know, ty!
Ben Kellogg
Unread 23-01-2009, 09:43
That sounds like you haven't permanently downloaded a program using the top menu bar FIRST -> Download to put your program on the cRIO.
What you describe is what you get if the cRIO isn't running a program.
Unread 23-01-2009, 12:25
jph399's Avatar
jph399 jph399 is offline
Programming
FRC #2500 (Herobotics)
jph399 is an unknown quantity at this point
You might have accidentally zapped your driver station and/or cRIO
Read this link:http://usfirst.org/uploadedFiles/Team%20Update%205.pdf
To-Do List synth3tk CD Forum Support 3 14-01-2009 18:37
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
Waiting List Weeeeeeeee Championship Event 4 06-04-2003 20:45
Match List Jack OCCRA 11 03-01-2003 12:33
Contact List... archiver 2001 1 24-06-2002 01:59
