Go to Post It's always better to figure out why a design actually works and the best ways to implement it than to just assume upgrading to a "better" material will make everything work. - Cory [more]
Unread 24-06-2002, 00:53
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Suggestion
Posted by Ed Sparks at 2/14/2001 7:45 PM EST
Engineer on team #34, The Rockets, from Bob Jones High / New Century High and DaimlerChrysler.
In Reply to: PBASIC HELP, ASAP!!
Posted by bill whitley on 2/14/2001 5:39 PM EST:
Bill,
If you find that you are still in big trouble with the programming after repeated attempts, post some detailed information about:
1) How you wired the devices to the controller
i.e. Left Wheel -> PWM1
Right Wheel -> PWM2
Compressor -> relay1
Pressure Switch -> rc_sw1
etc.
2) How you expect the 'bot to act given a program
3) Pictures of the 'bot
4) Which Operator Interface devices you want to use
i.e. Joystick 1(X&Y) operates drive system
Joystick 2(Y) operates arm
Joystick 1 (Trigger) operates ball claw
etc.
5) Which events you plan to attend (so we can find you if any of us are at the same event).
I'm sure this community will make every effort to get you going because:
1) We want you to have FUN ! We DON'T want you to start developing ulsers this early in life.
2) We care that you make points (we want them too after all).
3) We aren't challenged enough with just one robot to build
Not to sound like a wise guy but it kind of sounds like you COULD use an Engineer about now ........
I'll be at the Houston, KSC, and National events.
[IMG] code is Off
PBASIC ARCTAN function Greg Ross Programming 14 11-05-2003 12:28
Need to learn PBASIC...Where Should I Go? IMDWalrus Programming 5 29-04-2003 16:43
Obscure PBASIC for RoboEmu rbayer Programming 1 28-03-2003 23:57
PBasic 2.5 vs. 2.0 Anthony Kesich Programming 6 09-02-2003 22:06
PBasic Question Melissa H. Programming 28 17-11-2002 18:53
