Re: Yet another bumper thread
If you do ask, I'd love to know if one is permitted to machine small depressions into the back of the bumper, not exceeding 1/4" depth, exclusively to provide clearance for these fasteners so the bumper fits more snugly against the length of the chassis member/frame.
Official bumpers have aluminum angle top & bottom, so they might rest against the chassis and not wood. |
Ideally they would allow that, but if I remember right this has been illegal in previous years (I know that each year is different).
Jason |
The GDC has already answered: http://forums.usfirst.org/showthread...ighlight=angle
Relevant sentence: "Small spaces, up to the thickness of the aluminum clamping angles retaining the fabric covering, will be permitted between the bumper backing and the supporting structure." As long as your bolt head is no thicker than the aluminum clamping angle, you're all set. |
#7
This is one reason we decided to go with a wood chassis, with a 3/4" thick piece of plywood on either side of the wheels. The axle bolts can be countersunk, leaving a nice flat 5.5" tall, 26" long mounting surface for the side bumpers.
The kit frame is ok...but it leads to these fun problems.... How about adding a structural piece of 3/8" plywood along each side of the kit frame, with holes to make room for the bolt heads, and countersunk mounting holes on the outside to make room for flat head bolts that attach the wood to the frame. Eight feet of 3" wide 3/8" thick plywood weighs about 2 pounds, that would be enough to provide a handy mounting surface for the bumpers around two thirds of the BUMPER PERIMETER. Just an idea...use it, shoot it down, whatever you want ![]() Last edited by MrForbes : 16-01-2009 at 08:09. |
#8
Kevin,
Before an inspector will look at the bumpers, the size (and weight) of the robot is checked. Anything that is part of the robot must meet the sizing rules, including bumper attachment points. Should your design include bolts whose head or shank stick out of the frame, those projections must also fit within the sizing rule. If a team uses an attachment as suggested (i.e. threaded fastener with an internal "t" nut inside the bumper, then the removable fastener passes through the robot frame and is not part of the robot size. See "Cross-section View Figure 8 – 1" in the manual. Also... E. BUMPERS (including any fasteners and/or structures that attach them to the ROBOT) must weigh no more than 18 pounds. |
#9
So if we have a frame with say four uprights, the bumper can't just attach to the uprights? The sides have to be solid? That's what it looks like the rule says, but the Q&A answer was "Inspectors will be looking for structures sufficient to provide this function." Thoughts?
Brian |
#10
Hey, if you figure out that answer post it here. We tried asking yet another bumper question on Q&A and believe that they are avoiding us.
We are like may who use square extruded aluminum like ITEM for our chassis. We believe that the new rule requires us to reconfigure our design to make sure that the chassis frame makes contact with all 4 "edges" (horizontal and vertical) of the bumpers (plywood backing). So we redesigned the entire chassis versus adding material and adding weight of the chassis. |
#11
Pool noodle availabilty, try www.pooltown.net, in redford, MI phone # 1-888-397-pool. Thy have them $1.99 each.
#12
There's another bumper problem with the kit chassis while we're on the subject. In the short and wide configuration, you end up with a gap in either two or four corners of the frame. (See attached image) This leaves you with a ~1.5" diagonal on the bumper perimeter that cannot be protected by a bumper. Which means it's impossible to make the short and wide kit frame legal unless you build it 35.5" wide, or know to ignore the instructions, build it 36.5" wide and cut the outside bars long. Or other complicated things that rookies aren't going to know about.
I've posed this to the GDC, and I'm desperately hoping that they rule it legal to wrap the bumpers around this corner or extend them an extra bit to cover it. If they decide that teams will just have to modify the frames to make it possible to legally mount bumpers... Then I'm going to be somewhat annoyed with them and the prospect of helping 50% of the rookies at our regional get their bumpers legal. |
#13
#14
So you are correct. |
#15
If you want to follow the letter of the law, by building the kit frame as illustrated in the picture, you have actually created a very short 45-degree angled face to your BUMPER PERIMETER - somewhere in the neighborhood of 1.4 inches. This face has no frame backing to attach the BUMPER to. Never mind that you can't attach a 6" bumper to a 1.4" space.
Somebody please ask Q&A how to BUMPERize this corner. Following instructions given with kit parts should not lead you to violating the rules. |
| Another Bumper concideration | Wayne Doenges | Rules/Strategy | 8 | 20-02-2007 06:58 |
| Yet another website to critique | Joshua May | Website Design/Showcase | 11 | 18-10-2004 09:18 |
| yet another joystick question | Stormhammer | Rules/Strategy | 2 | 19-01-2004 10:10 |
| Yet another illustrator question | ryan_f | Computer Graphics | 3 | 02-09-2003 16:10 |
| Yet another scoring system... | archiver | 2001 | 0 | 23-06-2002 23:26 |
