Thread Tools |
Rating:
Display Modes |
Re: Precision Ground 1/2" 7075 Rod Supplier
Not knowing your design I cannot say for sure, but some things to think of...
#1 really think about your design, can you use normal 1/2" round bar and just turn the ends down where the bearings are to size? Further do you really need 7075? 6061 does pretty good for most uses. #2 that much AL weighs about 50LBS Could you turn tube down to the proper size?You may try igus, they make AL shafting meant to fit their plastic bearings (they work really well) website here http://www.igus.com/drylins.asp They list their shafting as .5 however I couldn't find true dimensions. They have a really nice program where you can get their stuff for free for school projects, they just ask you send them a photo and a writeup of what you did with it. Good luck |
If it were me, I'd try some of the stuff that is said to be +/- .0015" and is $20 for 8 feet. Now if it's a bit oversize, I might try using one bearing inner race as die, lube the axles and press them through, thus precision sizing them. (Or pull a long length through.) That or do a quick spin in a lathe with some abrasive paper or drawfile.
http://www.onlinemetals.com/merchant...192&top_cat=60 (Beware of specs - these seem pretty close for drawn rod.) If the shaft is undersized, I might try some Loctite 620 Bearing Mount or 641 Bearing Fit. Just a backyard mechanic's opinion, and not necessarily suitable for high speed, critical service. |
There is some reasoning behind our material choice (not the most sound as Travis pointed out though).
The biggest part is that we don't want any issues with fits. period. at all. Even if the shafts are the perfect size we want with the perfect fits and slide in nicely, assembly will be a pain. Having to adjust or custom fit 60' of shaft is not going to be fun. As for why we went with 7075, yes it is stronger than we need, but we found 6061 to not be strong enough. 2024 was another option, but the price difference is marginal between the two. Even when buying 60', the price different between 7075 and 6061 isn't much. We're looking at about $100 for all the 7075 we need, and we'd pay around $50 for the same amount of 6061; Twice the price, yes, but well worth the extra strength. Turns out that since PG is still larger than what we really want, and I'm not finding undersize 7075, we're planning on buying 5 12' lengths of 7075 rod (about < $20 each) and running them through a centerless grinder at either Cal Poly or a local shop. If that is unavailable, lots of kids, and lots of sand paper. Once these puppies are to size (ideally before we even buy them ) I don't want to any modifications required, I want them all to be interchangeable and with no additions or compounds. It would be well worth our team's money if we could pay $500 for undersize shafts, and save ourselves the hassle of all that work.Last edited by AdamHeard : 16-01-2009 at 13:42. |
You'll have to post a photo sometime Adam; what you're doing sounds like an intricate work of art.
| reducing sensativity of joystick for precision? | windell747 | Programming | 8 | 18-02-2008 10:15 |
| Precision of Shooting | Nitroxextreme | Robot Showcase | 0 | 10-02-2006 07:39 |
| Shooter Precision poll | NullTerminator | Rules/Strategy | 9 | 09-02-2006 23:23 |
| supplier for 5/8" shaft | david.clark | Kit & Additional Hardware | 2 | 17-01-2004 18:13 |
| Goal Drawings Precision | petrrj | OCCRA | 1 | 23-09-2003 21:01 |
