Go to Post ... you know you are a nerd when you want safety glasses for your birthday! :P - Ashley Christine [more]
Unread 16-01-2009, 07:21
Mike Mahar Mike Mahar is offline
FRC #0138
Mike Mahar will become famous soon enough
Re: Telling drivers station your alliance
Yes, adding a switch to the robot or the driver's station is easy enough but it is also easy to forget to set the switch in the heat of the competition and then your tracking is worse than useless. If you put the switch on the robot you lose the ability to correct is for the whole match. If lyou put it on the driver's station, then the information doesn't get to the robot during autonomous mode. Hopefully, the new field management system will allow driver station inputs during disabled mode.
That is why I'd like to use the built in alliance function.
Telling the drivers station your alliance Mike Mahar Technical Discussion 2 17-01-2009 12:24
pic: Drivers of the Winning Alliance JYang Extra Discussion 2 26-10-2008 21:55
Telling alliance in the code Andrew Schreiber Programming 4 30-01-2008 10:30
How does your team pick your drivers? Tton General Forum 14 08-04-2003 20:54
Members of alliance station... archiver 2001 2 24-06-2002 01:26
