Go to Post its not that I cant spell, I'm just being international. . . . I like it - Stuart [more]
Unread 16-01-2009, 08:38
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Trim for motors
A pure software solution would be to use a PID loop and a potentiometer.
The WindRiver code includes some very robust PID classes (see class PIDController in PIDController.h/cpp). I imagine the labview setup includes them too, but we're not a labview team so I don't know for sure. You just need to put a potentiometer on the arm joint, then use a PID loop to hit your desired arm positions. The nature of a PID loop will ensure that appropriate amounts of power are used to maintain your arm's position. Properly tuned, it will be faster, more accurate, more reliable, and have less oscillations than a human controlling.
Unread 16-01-2009, 09:40
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Trim for motors
Not related to code, but do NOT do this to a FP motor or the small RS545 motors (or whatever they're named). They do not take stall current very well at all, no matter how much power is being fed to them. In 2007, we managed to burn out 2 motors on our arm.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 16-01-2009, 12:20
qwv123 qwv123 is offline
FRC #1318
qwv123 is an unknown quantity at this point
Re: Trim for motors
Yes, PID works very well for this, unless you are lifting so much weight that the motors struggle to maintain their positions. If you are using LabVIEW, it does have several PID VIs, as well as some sort of autotuning PID wizard. My team has not used it, but it seems quite simple to implement.
Trim setting program Grogs Programming 1 10-02-2008 19:12
Setting Trim on Old 3D joystick jlewellen Programming 2 19-02-2006 21:03
Delphi set to trim 150 tech jobs Neal Probert Chit-Chat 4 03-03-2004 11:01
Fisher Price Motors for Drill Motors archiver 2001 0 24-06-2002 00:22
F.P. Motors & gearbox for $12.50 Window Motors $19.50 archiver 2001 1 23-06-2002 23:05
