Go to Post I don't think [Amanda] will have any trouble with Needel or the Kelsos but... I can understand Grady and we do have visible evidence of the menace that is Jessica Boucher. (just ask Billfred) - Al Skierkiewicz [more]
Unread 16-01-2009, 10:41
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: 4WD vs. Chain Drive
Originally Posted by Daniel_LaFleur View Post
The side will slip when the wheel with the least amount of traction breaks free because once that happends all of the torque from the slipping wheel will go through the chain to the non-slipping wheel and that will cause it to slip as well.
All of the torque? or the difference in torque between static and dynamic friction?
Thus 4 independently driven wheels will be slightly better ... although with traction control you may be able to compensate for the differences.
I agree that you can get a bit better traction with independent 4wd, but I also think you can do a lot with per side traction control.
In our case, we're using up all the motors on the ball handling stuff so it's a non-issue, we only have one CIM and one tiny Mabuchi motor (and the window motors) left for each side of the drivetrain.
pic: AM Mecanum Chain Drive MrForbes Extra Discussion 5 19-09-2007 02:44
Chain drive vs. cogged belt drive(timing belts) LordBritten Technical Discussion 24 20-12-2006 23:07
Chain Drive chain Damelvin 3D Animation and Competition 2 15-02-2005 00:19
Chain Drive Question Matt_Kaplan1902 Technical Discussion 34 12-04-2004 14:21
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
