Go to Post Heaven forbid. A hexed Vex. - Warren Boudreau [more]
Unread 15-01-2009, 21:12
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Yet another bumper thread
So before I ask the Q&A I wanted to run this by other CDers to see what they thought.
Using the KOP frame the proved axles are 3/8" bolts. This means that either the bolt head or the nut and bolt end rest outside the outermost frame rail.
In order to support the bumper along the entire length do we then have to mount another frame member above the chassis (with no bolt heads or nuts sticking out) running the whole length of the robot and sticking out from the chassis by the thickness of the bolt heads sticking out?
This seems a bit ridiculous to me.
Unread 15-01-2009, 21:22
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Yet another bumper thread
If you do ask, I'd love to know if one is permitted to machine small depressions into the back of the bumper, not exceeding 1/4" depth, exclusively to provide clearance for these fasteners so the bumper fits more snugly against the length of the chassis member/frame.
Official bumpers have aluminum angle top & bottom, so they might rest against the chassis and not wood.
Unread 15-01-2009, 21:28
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Ideally they would allow that, but if I remember right this has been illegal in previous years (I know that each year is different).
Unread 15-01-2009, 22:34
smurfgirl smurfgirl is offline
Still a New Englander on the inside
AKA: Ellen McIsaac
FRC #5012 (Gryffingear)
smurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond repute
In previous years, we have done that to our bumpers for that exact purpose, and they passed inspection. Of course, we have a whole new set of bumper restrictions this year, so I guess the best answer is to Q&A it...
Ellen McIsaac
Team 1124 ÜberBots 2005-2015
Team 5012 Gryffingear 2015+
Unread 16-01-2009, 01:56
dtengineering's Avatar
AKA: Jason Brett
They would not have passed tech on Galileo last year (several teams had to fix non-compliant bumpers) and should not have passed tech at any regional last year. Mind you, last year did specify NO holes regardless of purpose. This year's Q&A may be more forgiving.
Jason
Unread 16-01-2009, 07:31
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
We asked that exact same question last year and the answer was no. I would think that the tremendous loss of strength due to those tiny pockets would be largely offset by the better support of the bumper by the entire chassis, but the GDC thinks otherwise, or at least did so last year.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 16-01-2009, 07:36
GaryVoshol's Avatar
Cogito ergo arbitro
The GDC has already answered: http://forums.usfirst.org/showthread...ighlight=angle
Relevant sentence: "Small spaces, up to the thickness of the aluminum clamping angles retaining the fabric covering, will be permitted between the bumper backing and the supporting structure."
As long as your bolt head is no thicker than the aluminum clamping angle, you're all set.
(since 2004)
Unread 16-01-2009, 07:53
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
This is one reason we decided to go with a wood chassis, with a 3/4" thick piece of plywood on either side of the wheels. The axle bolts can be countersunk, leaving a nice flat 5.5" tall, 26" long mounting surface for the side bumpers.
The kit frame is ok...but it leads to these fun problems....
How about adding a structural piece of 3/8" plywood along each side of the kit frame, with holes to make room for the bolt heads, and countersunk mounting holes on the outside to make room for flat head bolts that attach the wood to the frame.
Eight feet of 3" wide 3/8" thick plywood weighs about 2 pounds, that would be enough to provide a handy mounting surface for the bumpers around two thirds of the BUMPER PERIMETER.
Just an idea...use it, shoot it down, whatever you want
Unread 16-01-2009, 08:12
Kevin,
Before an inspector will look at the bumpers, the size (and weight) of the robot is checked. Anything that is part of the robot must meet the sizing rules, including bumper attachment points. Should your design include bolts whose head or shank stick out of the frame, those projections must also fit within the sizing rule. If a team uses an attachment as suggested (i.e. threaded fastener with an internal "t" nut inside the bumper, then the removable fastener passes through the robot frame and is not part of the robot size. See "Cross-section View Figure 8 – 1" in the manual.
Also...
E. BUMPERS (including any fasteners and/or structures that attach them to the ROBOT) must
weigh no more than 18 pounds.
Unread 16-01-2009, 10:48
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
So if we have a frame with say four uprights, the bumper can't just attach to the uprights? The sides have to be solid? That's what it looks like the rule says, but the Q&A answer was "Inspectors will be looking for structures sufficient to provide this function." Thoughts?
Brian
Brian K
Team 1225 Robotics Mentor
Unread 16-01-2009, 11:03
Sunshine's Avatar
Sunshine Sunshine is offline
Mr. S
FRC #2062 (C.O.R.E)
Sunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to behold
Hey, if you figure out that answer post it here. We tried asking yet another bumper question on Q&A and believe that they are avoiding us.
We are like may who use square extruded aluminum like ITEM for our chassis. We believe that the new rule requires us to reconfigure our design to make sure that the chassis frame makes contact with all 4 "edges" (horizontal and vertical) of the bumpers (plywood backing).
So we redesigned the entire chassis versus adding material and adding weight of the chassis.
C.O.R.E. Community Of Robotic Engineers
2015 Wisconsin Regional Champs, Safety Award
2015 Midwest Regional Champs, Safety Award, Industrial Controls Award
2014 Midwest Regional Judges Award
2013 Lake Superior Champs
2012 World Championship Safety Award, World Finalist for the Autodesk Award
2011 Wisconsin Regional - Website Award 10,000 Lakes - Innovation in Control, Safety Award
2010 World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
2010 10,000 Lakes Regional Champs, Entrepreneurship Award; Wisconsin Regional- Entrepreneurship Award, Safety Award
2009 WI Regional- Quality Award, Safety Award 10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008 World Championship Safety Award
2008 Wisconsin Regional Champs, Safety Award
2008 St. Louis Regional Entrepreneurship Award, Safety Award, Website Award
2007 Wisconsin Regional All-Star Rookie Award
Unread 16-01-2009, 12:38
vannade vannade is offline
FRC #2591
vannade is an unknown quantity at this point
Pool noodle availabilty, try www.pooltown.net, in redford, MI phone # 1-888-397-pool. Thy have them $1.99 each.
Unread 16-01-2009, 13:04
Please know that the GDC is just as busy and perhaps more so than teams are at this point. They look at the questions (and there are a lot of them) and I would guess they have to make a decision as to which question best asks the question and how to answer it. I would not expect them to sit and wait for a question to be asked and then pounce on it. Please be patient.
Unread 16-01-2009, 13:08
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
There's another bumper problem with the kit chassis while we're on the subject. In the short and wide configuration, you end up with a gap in either two or four corners of the frame. (See attached image) This leaves you with a ~1.5" diagonal on the bumper perimeter that cannot be protected by a bumper. Which means it's impossible to make the short and wide kit frame legal unless you build it 35.5" wide, or know to ignore the instructions, build it 36.5" wide and cut the outside bars long. Or other complicated things that rookies aren't going to know about.
I've posed this to the GDC, and I'm desperately hoping that they rule it legal to wrap the bumpers around this corner or extend them an extra bit to cover it. If they decide that teams will just have to modify the frames to make it possible to legally mount bumpers... Then I'm going to be somewhat annoyed with them and the prospect of helping 50% of the rookies at our regional get their bumpers legal.
Unread 16-01-2009, 15:06
Maybe I'm missing something, but isn't it already allowed to extend the soft parts of the bumpers? See <R08-J> and illustrated in figures 8-2 and 8-4.
Another Bumper concideration Wayne Doenges Rules/Strategy 8 20-02-2007 06:58
Yet another website to critique Joshua May Website Design/Showcase 11 18-10-2004 09:18
yet another joystick question Stormhammer Rules/Strategy 2 19-01-2004 10:10
Yet another illustrator question ryan_f Computer Graphics 3 02-09-2003 16:10
Yet another scoring system... archiver 2001 0 23-06-2002 23:26
