Go to Post Let me tell you, the scariest day ever was the day that I realized since I am a mentor, people actually take my advice and I should be careful of what kind of advice I give. :ahh: - Elgin Clock [more]
Unread 15-01-2009, 18:30
nate15810's Avatar
nate15810 nate15810 is offline
World's Most Clueless Programmer
FTC #0154 (154 Renegade)
nate15810 is an unknown quantity at this point
Trim for motors
does anybody know any codes for trim for some ofthe motors?
we have an arm and 2 DC motors do not have enough torque to keep it up.
it needs to keep some power on the motors on all times.
Unread 15-01-2009, 18:44
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Trim for motors
Ahh, sounds like you need to counterbalance the arm.
There are several ways to do this. Add weight to the light end, like maybe using the motor it's self.
Add spring tension to the rear. Surgical tubing seems to be very popular.
Add a gas spring to the front side. The options are as numerous as your creativity.
Now here is something we might have tried this year if we had a need for it.
The pressure regulators are "relieving" regulators. That means that the low pressure side will be bled out if the pressure in that side exceeds the regulated setting.
So, use a piston to add a constant force lifting the arm. Set the regulator to the amount of force needed to balance the arm. The motor will then only be lifting the weight of the object being lifted or lowered.
Unread 15-01-2009, 21:29
Chipawa's Avatar
Chipawa Chipawa is offline
AKA: Mr. Tucker, AKA Chip
FRC #1111 (Powerhawks)
Chipawa is an unknown quantity at this point
Re: Trim for motors
Did you consider trying to use the window motors? These will hold their position when not powered.
2010 DC Engineering Innovation Award
2010 DC Spirit Award
2008 Chesapeake Finalist
2008 Chesapeake Rockwell Automation Innovation in Controls award
Unread 15-01-2009, 22:45
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Re: Trim for motors
I dont remember exactly how to program it but you could use a potentiometer to keep the location the same and the controller would constantly readjust the motors until they match what you want the location to be.
-Mike AA
Unread 16-01-2009, 08:34
FRC Key Volunteer Trainer
AKA: CrazyNate
Re: Trim for motors
A few years back(when I was working with 66), we used the van door motors(not sure if they are included this year or not, haven't really studied the KOP list for this year), along with the braking feature on the Victors, to successfully hang all 130ish pounds of our robot(the "breakaway claw" that we had that year, for those who remember it). Basically, we had both van door motors on opposite ends of a common winch pully(direct driving the pully), and relied on the Victor's braking option to keep us from sinking to get the "hanging" points at the end of the match...if the Jaguars have a similar feature(I think I remember reading they do, but with how my mind works, who knows if I'm right or not...), that might surve your purposes well...
Nate Smith
nsmith@smythsoft.com
Unread 16-01-2009, 08:38
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Trim for motors
A pure software solution would be to use a PID loop and a potentiometer.
The WindRiver code includes some very robust PID classes (see class PIDController in PIDController.h/cpp). I imagine the labview setup includes them too, but we're not a labview team so I don't know for sure. You just need to put a potentiometer on the arm joint, then use a PID loop to hit your desired arm positions. The nature of a PID loop will ensure that appropriate amounts of power are used to maintain your arm's position. Properly tuned, it will be faster, more accurate, more reliable, and have less oscillations than a human controlling.
Unread 16-01-2009, 09:40
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Trim for motors
Not related to code, but do NOT do this to a FP motor or the small RS545 motors (or whatever they're named). They do not take stall current very well at all, no matter how much power is being fed to them. In 2007, we managed to burn out 2 motors on our arm.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 16-01-2009, 10:21
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Trim for motors
This will work well, but remember that the orifice of the relieving regulator is very small. Probably on the order of .010" effective orifice size, maybe smaller. This means that while it will bleed out excess pressure, it will do so reletively (sp?) slowly.
___________________
- Tennyson, Ulysses
Unread 16-01-2009, 12:20
qwv123 qwv123 is offline
FRC #1318
qwv123 is an unknown quantity at this point
Re: Trim for motors
Yes, PID works very well for this, unless you are lifting so much weight that the motors struggle to maintain their positions. If you are using LabVIEW, it does have several PID VIs, as well as some sort of autotuning PID wizard. My team has not used it, but it seems quite simple to implement.
Unread 16-01-2009, 12:47
billbo911's Avatar
Re: Trim for motors
Wow, I didn't realize it was that small! You're absolutely correct, that might limit this systems usability. And, I'm certain we are not allowed to modify the regulators. I'll have to verify this against the rules.
[EDIT] Yep, can't be modified by my reading of rule <R71>
<R71>
In addition to the items included in the Kit Of Parts, pneumatic system items specifically permitted on 2009 FRC ROBOTS include the following items. All included items must be “off the shelf” pneumatic devices rated by their manufacturers for pressure of at least 125psi, and used in their original, unaltered condition (except as required for assembly with other components).
[/EDIT]
Trim setting program Grogs Programming 1 10-02-2008 19:12
Setting Trim on Old 3D joystick jlewellen Programming 2 19-02-2006 21:03
Delphi set to trim 150 tech jobs Neal Probert Chit-Chat 4 03-03-2004 11:01
Fisher Price Motors for Drill Motors archiver 2001 0 24-06-2002 00:22
F.P. Motors & gearbox for $12.50 Window Motors $19.50 archiver 2001 1 23-06-2002 23:05
