Go to Post Mob JVN for autographs - Jay Trzaskos [more]
Unread 16-01-2009, 11:29
frcchile's Avatar
frcchile frcchile is offline
FRC #2576
frcchile will become famous soon enough
How to program relay in labVIEW?
Hello, we're from team number #2576 from Chile, we want to programing the relays with 2 of the joystick's buttons.
We tried everything what we find but, we don't know how to do it
so please help us
Unread 16-01-2009, 13:36
dgraves702 dgraves702 is offline
FRC #0702 (Bagel Bytes)
dgraves702 is an unknown quantity at this point
Re: How to program relay in labVIEW?
Check under ACTUATORS in the WPI Robotics Library.
Keep in mind that they may not say "Relay" even if that's what they'll end up using. The LabVIEW code tends to take care of a lot of things behind the scenes.
I'll see what I can find when I get into the shop later.
As far as using Button 2 of the Joystick, use the Joystick GET VI and wire the Buttons output to an "Unbundle by Name". This will allow you to access Button 2.
How do you program joystick buttons in LabVIEW? darkpheonix NI LabVIEW 10 13-04-2014 10:20
Making the Labview program stick CDlabrador National Instruments LabVIEW and Data Acquisition 3 13-01-2009 20:19
Help to Deploy a Program in Labview. Delian NI LabVIEW 7 10-12-2008 21:13
Relay program? team877 Programming 11 04-02-2008 11:11
How to conect solenoids to the circuit board. and how to program it...??? arpitshah Pneumatics 6 13-01-2008 15:06
