Go to Post I always say find what works best for your team, for your given situation. Why should we rely on someone else to tell me what will work best for our situation? - JVN [more]
Unread 16-01-2009, 14:05
CraigHickman
Posts: n/a
Re: <R06>
Originally Posted by spc295 View Post
could the GDC rule that your maximum wieght be 120lbs, when you are full or moon rocks. for example if we weighed 119lbs, off the field then could we only pick up a certain number of moon rocks so that we would never be more then 120lbs. (not including bumpers and batteries) then a lighter robot say 115lbs could pick up more then the heavier robot? or does the maximum volume deminsions not include the weight of your payload. I am asking this becase of the recent ruling about the net bieng used to hold the orbit balls.
Unless you decide to make the balls part of your robot, they're considered field objects, and not robot components.
<R06> normal wear and tear Darkcrosbone Rules/Strategy 54 27-01-2009 18:03
R06 Questions SamM Technical Discussion 3 16-01-2009 14:50
R06 clarification Bruceb Rules/Strategy 6 06-01-2009 17:13
R06 - weight and configuration jimfortytwo Technical Discussion 6 18-02-2004 08:06
Rule <R06> Jack Technical Discussion 18 11-01-2004 13:36
