Go to Post You can't reprogram physics. - Kevin Sevcik [more]
Unread 16-01-2009, 14:21
Team2883's Avatar
Team2883 Team2883 is offline
FRC #2883
Team2883 will become famous soon enoughTeam2883 will become famous soon enough
Servos, DSC and labview
Has anyone hooked up a servo to the DSC and ran it in labview. If so how did you do it. If you could help us out that would be great.
Unread 16-01-2009, 14:34
Luke Pike's Avatar
Luke Pike Luke Pike is offline
Programmer
FRC #1501 (THRUST)
Luke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to all
Re: Servos, DSC and labview
Yes. First, you need to put a jumper on the pins next to the PWM ports you want to use for servos. Next, use the open/get/set servo vi's in LabVIEW to operate them.
Unread 16-01-2009, 14:47
Team2883's Avatar
FRC #2883
Luke thanks a ton.
Labview Servos quizbiz NI LabVIEW 5 09-01-2009 08:48
Working with spikes and servos in labview EROCK Technical Discussion 2 07-01-2009 11:38
Labview NXT Servos quizbiz National Instruments LabVIEW and Data Acquisition 1 30-12-2008 14:42
Rack and Pinion/Motors and servos psniffler Motors 7 25-01-2008 16:16
servos and the camera incognito_NICK Programming 5 09-02-2005 00:00
