Go to Post I approve of this misuse of machinery! - RoboChair [more]
Unread 16-01-2009, 14:39
jbbjjbt jbbjjbt is offline
VRC Coach
AKA: Jon T
VRC #0177 (Twisted Botz)
jbbjjbt is an unknown quantity at this point
Re: [FTC]: Help requested, the NXT is not showing the battery as being connected.
Double check that all of your wiring is correct. Check to see that the fuse in the battery is good. Use a voltmeter to measure the voltage on the motor controllers to make sure you are getting 12V nominal (13-14 actual). Is your battery charged?
Jon Thompson
Coach
VRC 177 Twisted Botz
Sponsored by FRC 122
NASA Knights
paper: Reading the FTC Battery Voltage PhilBot Extra Discussion 4 16-01-2009 08:46
[FTC]: Reading the 12V Battery voltage in LabVIEW PhilBot FIRST Tech Challenge 7 12-01-2009 21:13
Lie down the battery or not?! Nadav Gross Technical Discussion 8 03-02-2007 22:26
CMUCam Forum messages are not being poseted as recent activity in the portal Bob22341 CD Forum Support 3 31-01-2007 22:34
Anyone concerned about the possibility of not being allowed to go to Nationals? skrussel Championship Event 41 03-04-2003 11:35
