Go to Post If you never reach out and experiment with different things, you will never have the courage to reach out again. It's only through experiments and experiences where we get to understand ourselves better. - Ken Leung [more]
Unread 17-01-2009, 09:11
mahmosh's Avatar
mahmosh mahmosh is offline
FRC #1946
mahmosh is an unknown quantity at this point
which servo (step motor) allowed for this year?
hey all
our team wanna use a step motor.
which step motors allowed for this year (2009)? ...
Unread 17-01-2009, 09:55
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: which servo (step motor) allowed for this year?
None.
<R51>
Motors specifically permitted on 2009 FRC ROBOTS include:
A. All motors, actuators, and servos provided in the 2009 Kit Of Parts,
B. An unlimited number of COTS servos with a maximum output torque of 55 oz-in and maximum rotational speed of 100 rpm at 6 Vdc (e.g. HITEC model HS-322HD or HS-325HB servos, as provided in the Kit Of Parts),
C. An unlimited number of FIRST Tech Challenge (FTC) servos (HITEC HS-475HB servos),
D. One or two additional 2-1/2” CIM motors (part #FR801-001 and/or M4-R0062-12) in addition to those provided in the Kit Of Parts. This means that up to four, and no more, 2-1/2” CIM motors can be used on the ROBOT.
Unread 17-01-2009, 10:03
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
I think he was asking about the Hi-Tec servos, which you can use an unlimited amount. They are listed in R51-B in your response. Unlike past years where the manufacturer was specified, now they are listing specifications that cannot be exceeded. They are also listing FIRST challenge Hi-Tech servos in R51-C, unlimited quantities.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 17-01-2009, 21:36
mahmosh's Avatar
FRC #1946
our team want to use a servo for driving the robot not to use the camera
... not like HITEC HS-475HB servos
Unread 17-01-2009, 21:40
In that case, Indysam's answer stands.
<R52>Items specifically PROHIBITED from use on the ROBOT include:
A. Electric motors and/or servos different from, or in addition to, those in the Kit Of Parts, with the exception of those specifically permitted by Rule <R51>.
B. Electric solenoid actuators (note: electric solenoid actuators are NOT the same as pneumatic solenoid valves – the latter are permitted, the former are not).
I don't see any step motors/servos in the list in <R51>...
Now if you could rig a CIM or other KOP motor to act like a step motor or servo through some clever software and sensors, without modifying the motor itself...
Unread 20-01-2009, 20:25
mahmosh's Avatar
FRC #1946
mm.. i think we can use the jaguar itself .. by the jumpers on it with a limitswitch... true ?
Unread 20-01-2009, 20:28
You'd have to talk to the electronics/programming gurus around here for that.
Unread 20-01-2009, 20:43
mahmosh's Avatar
FRC #1946
OK .. THANKS
which gearboxes can we use for this year? mahmosh Kit & Additional Hardware 2 09-01-2009 19:52
Which wheels will you use for your robot this year? GO Groves 1213 Technical Discussion 44 03-02-2007 12:36
Only two batteries allowed this year? DKolberg Electrical 9 18-01-2006 23:19
Which teams are using a transmission this year Todd Derbyshire Scouting 10 08-04-2002 10:21
