Re: Encoder wheel loose on shaft
This is actually a fairly common problem. Take the disc off of the shaft, then using light pressure and a pair of pliers, squeeze the bands that hold the disc to the shaft in and close the gap between them. The disc should fit on the shaft snugly.
| Shaft encoder in KOP transmission? | MrForbes | Electrical | 7 | 24-01-2008 11:40 |
| Quadrature shaft encoder source | billbo911 | Kit & Additional Hardware | 7 | 06-01-2008 19:52 |
| VEX Shaft Encoder Kit | jeffmorris | FIRST Tech Challenge | 1 | 19-05-2006 12:23 |
| Which shaft encoder to use? | Jeff Waegelin | Electrical | 22 | 18-06-2005 03:57 |
| shaft encoder help | stephenthe1 | Programming | 2 | 03-12-2004 16:09 |
