Go to Post If you build offensively, keep defense in mind always for defense will always keep you in mind. - Molten [more]
Unread 17-01-2009, 10:39
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Encoder wheel loose on shaft
We put the encoders on the gearboxes last night. One of the wheels is loose on the shaft. Has this happened to anybody else? The wheel on the other gearbox was fine. Next question is what to do about it? Nurl the shaft? Rough it up with somethign else?
Thanks,
Brian
Brian K
Team 1225 Robotics Mentor
Unread 17-01-2009, 11:08
Schnabel's Avatar
Schnabel Schnabel is offline
Seriously I'm almost never serious!
AKA: Eric Schnabel
FRC #0469
Schnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond repute
Re: Encoder wheel loose on shaft
This is actually a fairly common problem. Take the disc off of the shaft, then using light pressure and a pair of pliers, squeeze the bands that hold the disc to the shaft in and close the gap between them. The disc should fit on the shaft snugly.
I win! XD
Shaft encoder in KOP transmission? MrForbes Electrical 7 24-01-2008 11:40
Quadrature shaft encoder source billbo911 Kit & Additional Hardware 7 06-01-2008 19:52
VEX Shaft Encoder Kit jeffmorris FIRST Tech Challenge 1 19-05-2006 12:23
Which shaft encoder to use? Jeff Waegelin Electrical 22 18-06-2005 03:57
shaft encoder help stephenthe1 Programming 2 03-12-2004 16:09
