Go to Post Hey people, I found out the answer to my question and that one guy eric is right all you have to do is read the manual. The rules are in chapter 7.3.5.1, sections - .:) - ronald [more]
Unread 17-01-2009, 13:37
frank.pendzich's Avatar
frank.pendzich frank.pendzich is offline
Mr.P
AKA: Mr. P
FRC #3011 (RoboWarriors)
frank.pendzich is an unknown quantity at this point
Festo Solenoid Doesn't Work
The Festo solenoid that came with our KOP works manually but not electrically. Under 45 PSI, the LED (yellow) indicator turns on but the state of the solenoid doesnt change.
There are many messages claiming similar problems and recommend an SMC replacement. We've been searching for hours for a direct replacement for the Festo solenoid and a distributor without luck.
Can anyone provide a SMC partnumber and source of supply for a direct replacement for the KOP Festo solenoid?:
Festo Single solenoid JP_1163 Pneumatics 4 24-02-2006 15:07
Festo solenoid wiring? computhief263 Pneumatics 1 15-02-2004 12:25
festo solenoid maxgebhardt Pneumatics 19 21-01-2004 23:06
Festo valve.... why wont it work? CHSguard72 Pneumatics 3 08-02-2003 19:07
sensor doesn't work PBoss Programming 7 29-01-2003 18:39
