Go to Post I know it's hard to believe, but there actually IS life after FIRST. - jleibs [more]
Unread 17-01-2009, 13:20
Marlfox's Avatar
Marlfox Marlfox is offline
FRC #1566 (Ammoknights)
Team Role: Electrical
Marlfox is an unknown quantity at this point
How do you connect surgical tubing?
I was wondering if anyone knew how to connect surgical tubing to make a conveyor belt.
You're about to be struck by a vehicle!
Unread 17-01-2009, 13:23
cardinalman86's Avatar
cardinalman86 cardinalman86 is offline
0001 0101 0010 1001 System Lead!!
AKA: Corey
FRC #1529
cardinalman86 will become famous soon enough
Send a message via Yahoo to cardinalman86
Re: How do you connect surgical tubing?
Just tie the ends together
or feed a string thru the surgical tubing and tie those ends together with a square knot and then tie it to the end of the surgical tubing
Before you practice zen, a bowl is a bowl and a cup is a cup. During zen, a bowl is not a bowl and a cup is not a cup. After practicing zen, a bowl is a bowl and a cup is a cup.
Unread 17-01-2009, 13:44
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
get the smallest zip-ties you can find. take four of them and with the first two make a loop by feeding them through each other. take the looped zip-ties and feed it into the tubing to make your belt. to lock it in place take your remaining two zip ties and tighten them over the large lock ends of the looped zip-ties.
Unread 17-01-2009, 14:02
gorillamonky gorillamonky is offline
FRC #0696
gorillamonky is an unknown quantity at this point
i think melt and stick will work
edit: glue?
Unread 17-01-2009, 14:08
sparrowkc sparrowkc is offline
AKA: Mark
FRC #1986 (Team Titanium)
sparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to behold
Tiny zip ties work well. We slit both ends of the tubing, like a snake tongue, glued them with rubber cement, and put two tiny zip ties around the joint. It seems to be holding up.
Unread 17-01-2009, 14:15
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
I haven't yet tried this method, but I have tested the fit and it seems like it should work.
Take the two ends of the surgical tubing piece you want to join and roll them back on themselves a short distance (turn them inside out). Take a small piece of KOP pneumatic tubing and coat it in adhesive (not really sure what would stick best). Roll the surgical tubing over the pneumatic tubing and let the adhesive set.
Unread 17-01-2009, 15:12
dtengineering's Avatar
AKA: Jason Brett
When prototyping you may want to just put a wrap of masking tape around the pneumatic tubing. That breaks up the smooth surface of the pneumatic tubing and gives the surgical tubing something to grab on to.
It is also possible to order urethane tubing specifically designed to work as conveyor belt material. Check out the McMaster-Carr catalog on page 1018, or search CD for "round tubing". You'll find there is lots of discussion on the topic.
Jason
Unread 17-01-2009, 15:19
Marlfox's Avatar
Your idea worked amazingly without any adhesive i'm sure it will work perfectly! Thank you!
Surgical Tubing spring rate? Tom Line Technical Discussion 9 30-01-2011 14:33
[OCCRA]: Surgical Tubing iwanttodunk OCCRA Q&A 1 07-10-2008 06:28
Where can you find Surgical Tubing ayjackson Kit & Additional Hardware 9 17-01-2008 15:12
Surgical Tubing punky2k1 Off-Season Events 1 24-10-2001 20:58
