Go to Post adulthood is overrated. people just give you wierd looks when you play with your transformers, nerf guns and lightsabres. - Tytus Gerrish [more]
Unread 17-01-2009, 14:09
teshazman's Avatar
teshazman teshazman is offline
Pro-Programmer
AKA: Shaz Man
FRC #1599 (Quantum Apocalypse)
Team Role: Driver
teshazman is an unknown quantity at this point
Question Nirio_device_open not found.
Hey guys,
In labview, when I run the first robotics default program, it has a non broken arrow, yet when it runs it outputs the error that it "can't find the nirio device in the digitial module". It tells me to use MAX to find the device location but I have no idea what MAX is and a windows search doesn't find nirio_device_open.vi
The other (maybe the same) issue is the DIO module function which I'm guessing is the module selector. Regardless of the module selected the program won't complete without an error. Trying to view the block diagram of the DIO selector asks us for a password, and we're not sure how it works in general.
The last thing is that we're not actually connected to a robot on the other end, and I think it might just be looking for a robot that isn't there. Any help or explainations would be greatly appreciated.
Unread 17-01-2009, 21:00
Re: Nirio_device_open not found.
Originally Posted by teshazman View Post
"can't find the nirio device in the digitial module"...we're not actually connected to a robot on the other end, and I think it might just be looking for a robot that isn't there.
That sounds like a good diagnosis. You can't run a cRIO program without a cRIO.
CMUCam2 Demo - File Not Found Error TechnoDrake LabView and Data Acquisition 6 12-01-2007 15:56
CMUCam2.llb not found Amin LabView and Data Acquisition 1 21-01-2006 18:31
Camera not found! SpeakerSilenced Programming 0 21-02-2005 12:54
Camera not found!!! Code\\Pilot Programming 11 02-02-2005 00:04
Header Not Found (adc.h) NotQuiteFree Programming 2 23-01-2004 16:26
