Go to Post Make sure you THOROUGHLY understand the rules of the game before you actually start designing the robot. - Koko Ed [more]
Unread 17-01-2009, 14:27
naruto137 naruto137 is offline
FRC #1656
naruto137 is infamous around these partsnaruto137 is infamous around these parts
Program Wirelessly
Is there a way that you can connect to the driver's station wirelessly by connecting 2 ports on the wireless bridge to both ports of the driver's station and connect the laptop to the bridge to connect to one of those ethernet ports?
Unread 17-01-2009, 14:33
Alexa Stott's Avatar
Alexa Stott Alexa Stott is offline
All I do is twin.
AKA: elixir
FRC #0025 (Raider Robotix)
Alexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond repute
Send a message via AIM to Alexa Stott
Re: Program Wirelessly
To download code wirelessly, you will need to configure your wireless network and connect everything appropriately.
Wireless bridge-->ethernet 1 on cRio
Router-->ethernet 1 on DS
Laptop-->ethernet 2 on DS
Make sure your IP is configured correctly on your laptop (10.xx.xx.6, default gateway: 10.xx.xx.4).
The manual for the proper configuration of the cRIO and the wireless network can be found here.
The entire manual can be downloaded here.
|Email:alexastott[at]gmail.com|Facebook|@zelixir|Google+|
[University of Maryland Computer Science, Psychology]
[Brunswick Eruption]
Unread 17-01-2009, 17:05
neutrino15's Avatar
neutrino15 neutrino15 is offline
plɹoʍ ollǝɥ
AKA: Jordan Perr
FRC #0694 (Stuypulse)
neutrino15 is just really niceneutrino15 is just really niceneutrino15 is just really niceneutrino15 is just really nice
I have had equal success just connecting my laptop to the wifi network and using DHCP. If you want, you can assign a static IP of 10.xx.yy.6 to the PC, but in our tests, this is not necessary.
Remember, there is nothing special about any of these ports.. Its just one big network..
Unread 18-01-2009, 09:12
It is only necessary to set your PC to a static IP of .6 if you want to use it to receive dashboard packets from the cRIO.
Those dashboard packets are sent via UDP exclusively to 10.xx.yy.6.
Cannot Connect to Axis Camera Wirelessly computerish Technical Discussion 4 11-01-2009 19:19
Can not connect bridge and router wirelessly team877 Programming 4 08-01-2009 00:18
Using an Operator Interface with the 2004 EDU RC wirelessly Dave Flowerday Robotics Education and Curriculum 34 19-04-2004 19:06
Need C Program! IrOnMeN_883 Programming 4 14-02-2004 17:36
VB program archiver 2000 0 24-06-2002 00:29
