Go to Post If you're destroying game pieces left and right, you're doin' it wrong. - Ian Curtis [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 17-01-2009, 15:54
Selijdice's Avatar
Selijdice Selijdice is offline
The Undertaker
FRC #3013 (The Zombots)
Selijdice will become famous soon enoughSelijdice will become famous soon enough
Send a message via AIM to Selijdice
The Andy Mark Chassie set problem?
Hey has anyone had a problem with the measurements. We have put together the chassies and we have found that it is about 37.5in long, but it's about 28 1/8" wide. The rules say the dimensions are 38" long x 28" wide x
60" tall. If we were to move the frame over one whole it would shorten the robot by an inch. So as I see it there saying if you want it to be exactly 28" then you need a custom part not a COTS. Does this seem weird or funny to you guys at all.
Unread 17-01-2009, 16:09
Booksy Booksy is offline
FRC #1244 (Viking Robotics)
Booksy will become famous soon enoughBooksy will become famous soon enough
Re: The Andy Mark Chassie set problem?
We just went with the 27 and a bit, to give us some play.
My favorite CD quote ever(taken out of context of course):
Originally Posted by ttldomination
water would be hard to build
Unread 17-01-2009, 16:12
The old IFI kitbot was always sent as a 38" square.
And you DON'T want it to be exactly 28" by 38". You want it at least an inch shorter to allow for bolt heads and the like that stick out. It's a lot easier than filing them down on Thursday at the event.
Unread 17-01-2009, 16:13
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Never design for exactly the dimensions. I imagine it was designed to be cut down a hole length, to allow for small things like bolt heads that stick off it.
Unread 17-01-2009, 16:14
We are making our bot 27 x 37 so that we have a bit of play to fit into the sizing box. It's less stressful that way when you are trying to get inspected. Also, if you are over by a bit or the robot isn't square (been there, done that because of on field collisions), you don't have to shorten the bot at competition.
Unread 17-01-2009, 16:31
Selijdice's Avatar
The Undertaker
Ok, I see now. Well we will just have to move it down one hole. Thank you guys.
Unread 17-01-2009, 18:11
rees2001 rees2001 is offline
AKA: Rees
FRC #0340 (Greater Rochester Robotics)
rees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond repute
Don't forget that the axle bolt heads stick out of the frame. Not something you had to think about with the IFI frame.
Unread 17-01-2009, 18:18
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
its lighter too.....
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
andy mark wheels delay nuggetsyl General Forum 27 08-01-2009 22:18
andy mark plaction wheel gorrilla Technical Discussion 2 05-10-2008 15:25
2 motors on 1 Andy Mark transmission Japper Technical Discussion 9 16-09-2008 22:17
Andy Mark Super Shifter tony.dalia.195 Motors 33 16-05-2008 01:15
Andy Mark (reliable???) cobrawanabe1699 Technical Discussion 31 15-01-2008 12:55
