Go to Post Most members of the CD community are happy to help one another. But searching before you post is standard forum etiquette... - KathieK [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 17-01-2009, 16:59
jtd07 jtd07 is offline
FTC #2641
jtd07 can only hope to improve
Direct drive from Toughbox?
We have been trying to scrap up ideas for a direct drive from the KOP toughbox's... one problem, we would use the shaft on the oppposite side of the motor how does the wheel connect to the shaft??
Unread 17-01-2009, 17:19
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Direct drive from Toughbox?
Ok, you need to either hex or put a key way on the wheels. If you go with the keying idea. You will need to add a hub to the wheels and have the hub bored out to the size of the toughbox shaft. Add a keyway to the hub and your done.
Hex would be my preference. Make a hub that has a hex on it. You will need an arbor and broaches. On the toughbox you will need to make a custom shaft aka hex shaft. Since Andy hasn't released the hex bearings yet. You need to either turn down the shaft to a 3/8th's hex or make a 1/2 hex shaft. Get a bigger bearing and buy a hex sleeve for it.
Need more info, email me.
R.C.
MadTown Robotics Team 1323
Unread 17-01-2009, 17:27
FTC #2641
cool we did something simliar to that last year, BUT would you still need bearings in the wheel?
Unread 17-01-2009, 18:15
dtengineering's Avatar
AKA: Jason Brett
Andymark has some ideal solutions for that, including an extra long output shaft and several hubs that allow you to mount the KoP wheels directly on it it. Go to www.andymark.biz and take a look at the options available to you.
We're casting and turning our own hubs, rather than buying them, but we did get the long output shaft.
Jason
CIM direct drive robomaxx Motors 23 15-05-2008 22:30
Wheel direct drive molly Technical Discussion 15 25-01-2008 00:32
Direct Drive from Toughbox Gearbox diesel Technical Discussion 11 16-01-2008 04:30
pic: 1097 Direct Drive 01 Anthony Kesich Robot Showcase 16 13-09-2005 22:33
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
