Go to Post Unfortunately I think IFI made us buy a new one. Something about 200amps across the power connector not being a warranty item. - GeorgeTheEng [more]
Unread 17-01-2009, 17:22
Re: COF help?
Originally Posted by Booksy View Post
It is in the manual. gel-coated, fiberglass-reinforced, polymer material. Now wether they are referring to the frp being naturally gel coated or it being an additive is another story.
It's naturally gel-coated; or rather, that's how it's sold. The only treatment is to put it on carpet and tape it down with fiberglass tape.
Unread 17-01-2009, 17:27
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: COF help?
This has been dicussed on another thread, but man that floor is gonna be gone in a day. We drive on it and it just powder. Happy Snow Day teams.
R.C.
MadTown Robotics Team 1323
Unread 17-01-2009, 19:34
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
Re: COF help?
We get repeatable results with both the incline and pull force methods.
The conditions are new undamaged wheels and new undamaged Glassliner FRP from home depot.
We see static mu of 0.12 +- 0.02 and transverse of 0.13 +- 0.02. All measurements taken with 4 wheels.
At this point, I for one do not believe static mu of 0.05 without some form of lubrication on the floor. But those are the FRC numbers and they are sure sticking to them.
As a further aside, I cannot think of any way to traverse 48 ft of floor in 6 seconds in a standard kit bot frame without mu > 0.083, but then again I could be missing something.
In any case, we are preparing for static mu to be in the range from 0.06 to 0.15 and for the dynamic/static ratio to range from 1.0 - 2.5. As long as you can work under the full range of conditions you should be OK.
Unread 22-01-2009, 13:18
Jared Russell's Avatar
Taking a year (mostly) off
Re: COF help?
Equations:
F = m*a
F = u*N
m*a = u*N
Plugging in:
(mtrailer + mrobot) * a = u * mrobot * g
a = (u * mrobot * g)/(mtrailer + mrobot)
Let mrobot = 120lbs + 18lbs (bumpers) + 7lbs (battery) + 5 lbs (trailer tongue weight) = 150 lbs = 68.0 kg
Let mtrailer = 35lbs (not supported by the robot) = 15.9 kg
a = u*68.0*9.8/(68.0+15.9)
a = u*7.94 m/s^2
We know that:
x = .5*a*t^2
If x = 48 ft = 14.6 m and t = 6s, then
14.6 = .5*a*36
a = 0.811 m/s^2
Plugging back into our first equation...
0.811 m/s^2 = u*7.94 m/s^2
u = .102 (at least)
Possible Conclusion 1: If we are to believe Dave's claims about traversing the field forward and back in about 12 seconds, then the published FIRST figures must be wrong.
Possible Conclusion 2: FIRST measured their CoF on a worn floor, while Dave drove on a new floor.
FWIW: Our new wheels on new regolith came out to about u=0.10
Unread 22-01-2009, 13:21
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: COF help?
This is the type of thing I would expect to have happened
Unread 22-01-2009, 13:44
Booksy Booksy is offline
FRC #1244 (Viking Robotics)
Booksy will become famous soon enoughBooksy will become famous soon enough
Re: COF help?
If the CoF really is about 0.1, then that is good news for linoleum, because we measured about 0.13-0.16 on linoleum, so it turns out to be a better analog than we initially thought.
My favorite CD quote ever(taken out of context of course):
Originally Posted by ttldomination
water would be hard to build
Unread 22-01-2009, 16:40
jgraber jgraber is offline
jgraber is just really nicejgraber is just really nicejgraber is just really nicejgraber is just really nice
Re: COF help?
Equations: ...
14.6 = .5*a*36
a = 0.811 m/s^2
u = .102 (at least)
Lovely math.
Your model is driving full speed end to end, without even a turnaround and decel. Top speed before hitting the wall is 0.811m/s^2*6s = 4.866m/s.
Does the stock transmission setup support that top speed?
To get to half-field in 3 seconds with this same accel, your initial velocity has to be 1.21m/s, or about 1.5s worth of accel. To summarize: u=0.102 also supports a model of accellerating to midfield, instant reverse accel, and bounce off walls perfectly elasticly at a bounce speed of 1.2m/s. This model drops the top speed to 3.64m/s by raising the average speed.
I wonder how it works out if you assume a lesser elasticity, like 80%, and a late non-midpoint reversal. ie faster crash, slower bounceback
A video of someone doing laps with trailer on a real field would be awesome.
Mass of MoonRock payload is assumed to be neglegible.
Re COF measurements: Is there a difference between static friction with a rolling wheel, vs static friction on a fixed wheel? It sounds like most people are measuring with a drag sled fixed wheel.
Unread 23-01-2009, 11:15
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
Re: COF help?
Originally Posted by jgraber View Post
Lovely math.
I have observed, but not measured, significantly lower COF when static friction is lost.
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
Unread 23-01-2009, 11:18
Re: COF help?
Rolling friction (where the surface of the wheel at its bottom point doesn't slip relative to the floor) should be equivalent to static friction for non-deformative surfaces.
Unread 27-01-2009, 21:27
Re: COF help?
Yes, so I have been taught as well. I'll rephrase my comment/question as
"When reporting local COF measurements, please include details of your methodology, such as using a fixed wheel drag sled, vs using a weighted robot with KOP wheels pulling a scale pulling a dragsled.
Unread 01-02-2009, 09:24
Generator of Entropy
FRC #2973 (The Mad Rockers)
Re: COF help?
So I assume you have an algorithm in your drive code that determines when your wheel is slipping and backs off the power? Certainly possible - compare omega R of the wheel to integrated speed at the wheel from the yaw rate and accelerometer. Or just calculate it from static friction and never apply more than that amount of power, but if you do start to slip it's not self correcting since the power requred decreases. Otherwise if you're applying full power to the wheels you can expect them to slip.
Unread 21-01-2009, 16:26
The_Laughing_ManMII's Avatar
The_Laughing_ManMII The_Laughing_ManMII is offline
FRC #1361 (The Nightmares)
Team Role: Driver
The_Laughing_ManMII will become famous soon enoughThe_Laughing_ManMII will become famous soon enough
Re: COF help?
Conjecture:
The powder is the difference between the .06 quoted and .12 measured. After all, regolith means a layer of fine powder/dust on the moon. Maybe they are assuming the surface will be all jacked up and we will be driving on the powder which will then make the coefficient of friction more like .06
The question is not how far you must go, but how far you will be willing to go to achieve that what is needed. - Father from the Boondock Saints
Unread 22-01-2009, 08:49
Warren Boudreau Warren Boudreau is offline
FRC #0180 (Team SPAM)
Warren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond repute
Re: COF help?
We got the same results this weekend. COF around 0.12 to 0.14.
Good news for most (more traction), bad news for anyone who was planning on using smaller motors on the drive train (Banebots or Globes), like us.
Oh well, bring in the CIMs.
Warren B
Pool Noodles. They're not just for bumpers anymore.
Cof XXShadowXX Technical Discussion 1 05-01-2009 08:54
Grab Frame - Help Help Help... nmihailidis Programming 2 04-03-2007 14:44
section 'InterruptVectorLow' type is non-overlay (was: HELP HELP HELP!!!!!) naor52 Programming 14 24-02-2007 01:19
Help: How do we get a teacher to help? (was: Help) ChaosAlchimey General Forum 13 21-01-2007 11:57
.cof help errors rholokleolke Programming 2 27-01-2006 11:01
