Go to Post Changing lives as a key volunteer is not a right reserved for the "elite" among us anymore. - HurdFIRST [more]
Unread 17-01-2009, 17:21
meastman meastman is offline
FRC #1245
meastman is an unknown quantity at this point
Gearbox Key
Has anyone else had the problem of the key flying out of the motor shaft in the gearbox? We ended up creating a collar to keep them on.
Unread 17-01-2009, 17:28
ironbears ironbears is offline
Alex@854
AKA: Alex
FRC #0854 (Ironbears Team 854)
ironbears is on a distinguished road
Re: Gearbox Key
just fixed ours today. your talking about the andymark toughboxes? i put that several of those black washers on mine. one kept it down and the 2nd kept it from sliding out. i believe your talking about the CIM gear?
Iron Bears Team 854
Rookie Year 2002
2008 ON Xerox Creativity
2007 WAT Rockwell Automation Innovation in Control
2007 WAT Regional Finalist
2007 ON Motorola Quality
2007 ON Regional Finalist
2006 ON Motorola Quality
2005 ON RadioShack Innovation in Control Award
2005 WAT RadioShack Innovation in Control Award
2003 ON Delphi "Driving Tomorrow's Technology"
2005 The Championship Event (4/21/2005 - 4/23/2005)
2003 The Championship Event (4/10/2003 - 4/12/2003)
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Gearbox Key
No, but we used our own keystock.
R.C.
MadTown Robotics Team 1323
Unread 17-01-2009, 17:47
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Gearbox Key
We had the same thing happen. Not a big deal. Just make sure a tooth of the locking snap ring is in the keyway, or put some sort of little nylon spacer/washer or something.
Unread 17-01-2009, 22:12
rogeryoung rogeryoung is offline
FRC #2063
rogeryoung is an unknown quantity at this point
Re: Gearbox Key
We finally got out drive train put together and tested it by powering up the motors. One side was fine the other started working then just the quiet whirl of the motor spinning. Someone saw the 1/16" key sitting inside the gearbox. I had two of my freshman working on it today. They took it apart, we fixed it and tried it again. Same thing. Must have taken it apart three times. I'm going to go get a longer key tomorrow. That should solve the problem.
Unread 17-01-2009, 23:48
NoahTheBoa's Avatar
NoahTheBoa NoahTheBoa is offline
AKA: Noah Tomaszewski
FRC #0968 (RAWC)
NoahTheBoa has a spectacular aura aboutNoahTheBoa has a spectacular aura about
Send a message via AIM to NoahTheBoa
Re: Gearbox Key
We've had the same problem in our gearboxes. We put some loctite on the key and made sure we had a tooth of the lock ring on top of the key.
Team 968 (Mentor) 2011
Team 1138 (Mentor) 2010
Team 1138 (Student) 2005-2009
Unread 18-01-2009, 00:36
Re: Gearbox Key
Or just read the post above yours.
Just add a washer and you're good to go. The toughboxes this year did this and its easily fixed with a washer.
Unread 18-01-2009, 01:00
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
Re: Gearbox Key
Yup we had the same problem, just add a washer like said above. I picked a smaller diameter one and turned it on the lathe to make a tighter fit.
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 18-01-2009, 04:15
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Gearbox Key
Just because a tooth on the lock ring lines up with then keyway doesn't mean your key is safe. That's an assumption that 228 made last year, only to have the machine key fall out when it slid through a gap in the teeth (somehow the lock ring rotated).
If you use a [tight fit] washer with the lock ring, or alternately a shaft collar, you can prevent this. The CIM shaft is 8mm diameter, which is only a few thousandths larger than 5/16"; you should be able to use an oversize tolerance 5/16" washer.
Art Dutra IV
世上无难事,只怕有心人.
Unread 18-01-2009, 05:55
Re: Gearbox Key
Just a note, it is a 2mm key.
Offseason gearbox project... maybe this gearbox has helical gears? Travis Covington Technical Discussion 17 05-06-2006 11:48
Hex vs. Key alysume Technical Discussion 12 31-05-2006 22:37
Registration Key laditek Programming 2 13-01-2006 11:11
2 mm key stock Andrew Technical Discussion 8 03-02-2003 22:29
Traction is Key >^..^< archiver 2001 0 24-06-2002 02:37
