Go to Post My driving skills are only slightly better than my dancing skills... - RoboMom [more]
Unread 17-01-2009, 09:36
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
Encoders — Noise
Hello teams,
How are you going about and "cleaning" up the encoder signals? I'm getting as high as 100rpm "jump"... When the speed is low, it's tolerable, but at high speeds it reads 700 then next reading reads 900 then reads over 1000 then jumps down to 700 and it's just horrible.
I've looked in to the signal processing sub-vis and they are just way to complicated. If anyone can make that signal a clean one, please let me know!
Thanks,
Keehun
Team 2502
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 17-01-2009, 11:39
wt200999's Avatar
wt200999 wt200999 is online now
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Encoders — Noise
Is it possible that this is your problem:
http://www.chiefdelphi.com/forums/sh...ad.php?t=72176
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 17-01-2009, 11:52
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
We spent days on the encoder rate problem, before we gave NI enough information for them to isolate the FPGA bug.
Here's the thread that includes our testing:
http://forums.usfirst.org/showthread.php?t=11004
Unread 17-01-2009, 19:10
bayesianlogic bayesianlogic is offline
ekzept
AKA: Jan Theodore Galkowski
bayesianlogic is an unknown quantity at this point
Well, while I don't know anything about the details of these encoders, averaging -- presumably over some kind of lagging window -- is not the best approach. First of all, averaging is sensitive to outliers, so one spike will pull the mean of a group of samples high for the duration of the time it remains in the window. Second, averaging will lag the current value by typically a half window width, possibly longer, even if the window is optimally weighted. It's possible that because it's an encoder, the lag isn't so critical. Third, it depends upon how many impulsive values you get in a typical timeframe and whether these are bursty or not. Bursts are difficult to handle without introducing lags no matter what's done. If lag's a problem, getting a better sensor might be your only answer.
The other approaches are to use a different kind of processing. Instead of averaging, try a median in a window having an odd number of taps. You might also look into hysteresis smoothing, although if the signal is really impulsive or bursty, that won't help much. You could try combinations.
It's difficult to recommend more without looking at a dataset capturing a series of outputs from such an encoder.
Unread 17-01-2009, 19:22
j_johnson j_johnson is offline
FRC #0226 (Hammerheads)
j_johnson is an unknown quantity at this point
We are using Windriver, but were able to set up a task (indirectly through the PIDController) that retrieved the encoder count every so often (about 20 ms for us), and dividing the difference in encoder counts by the time between checking. If you are using Labview, I believe it has a timed loop that you could use for something similar.
Unread 19-01-2009, 01:37
AKA: Randy
Doh, I was obsessing about the FPGA bug and didn't consider that distance was correct and I could get delta times to compute the speed in LV.
Thanks for reminding me.
CIM Noise whytheheckme Motors 5 14-02-2008 11:34
microcontroller picking up noise? sciguy125 Electrical 24 18-09-2007 22:14
PWM Signal Noise? Danny Diaz Electrical 3 28-01-2007 17:02
Noise Makers!!!! skitz547 Chit-Chat 26 02-02-2003 00:30
Noise Emission Problem... archiver 2001 3 23-06-2002 23:30
