Go to Post Wow, I am beginning to feel like a member of the fabled "vast right-wing conspiracy" :) - Jim Zondag [more]
Unread 17-01-2009, 20:36
dnrobotics11 dnrobotics11 is offline
FRC #2589
dnrobotics11 is an unknown quantity at this point
WindRiver Programming
How do you compile the different class templates such as the camera and the gyroscope with the main template into a single program download to the cRIO? Are these compiled independently? Which manual is best for these questions for WindRiver programming and downloading?
Unread 18-01-2009, 14:51
cj.reeves cj.reeves is offline
FRC #2589
cj.reeves is an unknown quantity at this point
Re: WindRiver Programming
study for midterms
Unread 19-01-2009, 15:45
FRC #2589
Somebody please help!
Unread 19-01-2009, 15:56
gokul gokul is offline
FRC #0571
gokul is an unknown quantity at this point
Start with a base program.
Then copy the files from other projects to this new project's folder (in the workspace).
Make sure you copy the correct .h files also - you need only .cpp and .h files.
Now, you will have to make sure that the key START_ROBOT_CLASS statement is ONLY in your main program and no place else. It should also reference your program (class) only.
By #include'ing correct .H files and referencing the correct classes/methods from the other files you should be able to get a good build.
Hope this helps!
Unread 19-01-2009, 19:43
FRC #2589
Thank you very much for the help. How do you call each of the other classes within the main template? I understand that you use the .h files to reference them but how do you indicate when to "activate" the separate code (such as the camera or the gyroscope)? I appreciate your help very much.
WindRiver Errors ExarKun666 C/C++ 7 04-03-2009 20:32
Windriver LAC McGurky C/C++ 12 25-02-2009 18:38
Getting Familiar with Programming in WindRiver kyungjin C/C++ 35 17-01-2009 13:04
compiling in windriver koreabell Programming 4 05-01-2009 15:32
