Go to Post All screws are not created equal. - Al Skierkiewicz [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 17-01-2009, 15:13
B.Collette's Avatar
B.Collette B.Collette is offline
Jack of all Trades
FRC #2342 (Phoenix Robotics)
B.Collette is on a distinguished road
Send a message via AIM to B.Collette
Can someone explain this to me?
Now for the record I am a seasoned designer and programmer and I make websites for a living. But for the life of me I can not figure out why Internet Explorer (grrrr) is doing the things it's doing.
If someone could take a look at the front page and give me an idea that'd be wonderful. http://phoenixrobotics.net/ (remember to look in IE because it seems to work everywhere else)
Thanks
/brian
....::: Team Phoenix 2342 :::....
Phoenix Robotics
Flickr
'08 Rookie All-Star Award Winner
Unread 17-01-2009, 15:42
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: Can someone explain this to me?
Not sure why you are putting it site into an iFrame. If I copy source url from the iframe and view it in IE, it looks just like Firefox and Chrome.
http://phoenixrobotics.net/index.php?ieframe=true
Unread 17-01-2009, 16:12
B.Collette's Avatar
Jack of all Trades
http://phoenixrobotics.net/phoenix/website.png (it's to big to post but this is what it has looked like for me since I first made)
/brian
Phoenix Robotics
Flickr
Unread 17-01-2009, 20:09
bobwrit's Avatar
bobwrit bobwrit is offline
//No Comment
AKA: ...
FRC #1977 (Loveland High Robotics)
bobwrit is just really nicebobwrit is just really nicebobwrit is just really nicebobwrit is just really nicebobwrit is just really nice
I think it may have to do with the file type of the logo. Also IE is telling me that there is an error on line 49 of the source code, If that tells you anything(IE 6 specificly)
FRC Team 1977 Alumni
Has Attended:2008 Colorado regional
2009 Colorado Kickoff
2009 Colorado Regional
2010 Colorado Kickoff
2010 Colorado Regional
The most exciting phrase to hear in science, the one that heralds new discoveries, is not "Eureka!"(I found it!), but rather, "Hmm.... That's funny" ---Isaac Asimov
Chance favors the prepared mind ---Louis Pasteur
And you can tell me, that I can't make a diffrence because I'm just one, but one is all it takes to start it. And you can tell me, that I can't change the world because I'm too young, but I wont stand here and be your target. ---FM Static
Unread 17-01-2009, 20:55
DMetalKong's Avatar
DMetalKong DMetalKong is offline
AKA: David K.
DMetalKong is a jewel in the roughDMetalKong is a jewel in the roughDMetalKong is a jewel in the rough
Send a message via AIM to DMetalKong
Couldn't tell you exactly what the problem is, but it might be easier to replace the images with css-ed text than try to do a fix for IE.
Unread 17-01-2009, 20:57
cdennisxlx2's Avatar
cdennisxlx2 cdennisxlx2 is offline
Team San Diego Web Liaison
AKA: Cameron Dennis
FRC #1266 (The Devil Duckies)
cdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to behold
try not using a specific style sheet for IE. If you notice it will load correctly then about a second later it will mess everything up. The reason for that is that IE is loading the main style sheet then realizing that you don't want it to load the main one and loads the IE one.
Also you should never make your left position static, for those of us with monitors that have either a higher or lower resolution then yours it will either place it self on the left side of the window or will be cut off on the right.
You have:
margin: 0 0 0 250px;
Would look better with:
left: 50%;
margin-left: -450px;
position: absolute;
this will make it dynamic so it will always be in the center of every ones resolution
Team San Diego Robotics Web Liaison
Webmaster and Technical Advisor for the San Diego Regional Planning Committee.
Official Score Keeper for the San Diego Regional
www.sandiegoregional.com
www.frc1266.com
Unread 17-01-2009, 23:05
Vpr99's Avatar
Vpr99 Vpr99 is offline
Not quite a person... yet
AKA: Eric Skram
FRC #0159 (Alpine Robotics)
Team Role: Webmaster
Vpr99 is an unknown quantity at this point
Send a message via MSN to Vpr99
Also, keep in mind that IE6 has a double margin bug. This means that when you put margins on certain objects, then the margins will be doubled. To fix this, then duplicate the style in the stylesheet, but add * html before it. Divide the margin in half also. This works because all browsers but IE6 identify * HTML as not a valid CSS command. Due to another unpatched bug, IE6 accepts that as a command, so it works if you want something to only work in IE6.
Here's an example from the stylesheet of a current project:
#content .interpage_links .sponsor {
	margin-top:10px;
	padding-right:10px;
* HTML #content .interpage_links .sponsor {
	margin-top:5px;
	padding-right:10px;
Hope this is useful in your designing
Unread 19-01-2009, 20:03
RyanCesiel's Avatar
RyanCesiel RyanCesiel is offline
Project Manager / Web Designer
FRC #0245 (AdamBots)
RyanCesiel has much to be proud ofRyanCesiel has much to be proud ofRyanCesiel has much to be proud ofRyanCesiel has much to be proud ofRyanCesiel has much to be proud ofRyanCesiel has much to be proud ofRyanCesiel has much to be proud ofRyanCesiel has much to be proud ofRyanCesiel has much to be proud of
Send a message via AIM to RyanCesiel Send a message via Yahoo to RyanCesiel
Well it's a little useless having those links as images. Simply use Trebuchet MS, if it's not the font you're using, it looks very close.
I would suggest having consistent formatting throughout your site as well. I noticed your Gallery and phpBB forum have default themes set.
AdamBots.com - Winner of 10 Best Website Awards!
Can someone post this on streamline 4 me? Salik Syed 3D Animation and Competition 2 22-02-2005 03:06
Can anyone explain to CAD to me? Vashts6583 Inventor 4 16-01-2005 18:17
Can someone post this on FIRST q/a Joe Ross Electrical 23 16-02-2004 17:28
Can someone explain this to me... Suneet 3D Animation and Competition 1 21-09-2002 02:36
Can Anyone explain the FIRST lego legue archiver 2001 7 24-06-2002 02:58
