Go to Post The real world doesn't snap together easily. - Joe G. [more]
Unread 17-01-2009, 19:16
pinballwizard96's Avatar
pinballwizard96 pinballwizard96 is offline
Ludologist, audiophile, etc
FRC #3021 (The Caiman Agents)
pinballwizard96 is an unknown quantity at this point
trouble setting IP addresses...
unsure how to set ip addresses for the devices - I followed the FRC document instructions but I don't think it affected the devices and I do not know how to check this...
the driver station is updated but the cRIO is not - I was attempting this in order to do so.
Thanks in advance
EDIT: messing with the addresses must have done something because the driver station now labels the cRIO as invalid mode and system when connected properly
pinballwizard96
"The Enrichment Center is committed to the well being of all participants. Cake and grief counseling will be available at the conclusion of the test. Thank you for helping us help you help us all." -Portal
http://www.youtube.com/watch?v=VnqpOFcBiMM
Unread 17-01-2009, 21:54
Re: trouble setting IP addresses...
Just update your cRIO using the FRC cRIO Imaging Tool. You will tell it your team number, and it will use that to set the IP address correctly.
Unread 18-01-2009, 12:03
So I should be able to do that and it will set addresses for all 6 devices we need to change? Personally, I don't have access to the actual equipment until Wednesday (another team member is working on it until then), but we managed to configure our laptop and router correctly. When I ran the imaging tool it failed when trying to connect to the cRIO (I had the unit's port 1 connected to the PC). The information in the program window was as follows:
MAC address: (don't know)
Name: temp (why temp?)
IP: (can't remember - was 10.30.21.?)
Environment: LVIEW
Format controller - image was the latest zip file don't know file name
We filled in the device name and team number in line correctly.
Is there anything wrong with the above info?
pinballwizard96
Unread 19-01-2009, 20:05
AKA: Brad
#0190 ( Gompei and the Herd)
The cRIO Imaging Utility will only set the IP address for the cRIO based on your team number. You'll have to set the other equipment (laptop, access point, gaming adapter and DS) as described in the configuration document on the FIRST web site.
Brad Miller
Robotics Resource Center
Unread 20-01-2009, 22:42
Solved. Thanks for the input.
pinballwizard96
Trouble setting team number in OS Gene F National Instruments LabVIEW and Data Acquisition 4 08-12-2008 08:26
Setting Up... jumpe1990 Regional Competitions 3 18-03-2008 17:16
pic: Dean Kamen Addresses Crowd at Bayou Regional Pjohn1959 Extra Discussion 0 12-03-2007 16:22
Inventor software trouble/ FIRST Base trouble nasa-senpai General Forum 2 24-01-2007 09:15
Thank you addresses? KKJS709 Thanks and/or Congrats 1 18-05-2002 20:30
