Go to Post You mean i can do something with the Kinect other than put large dents in wall with a robot? Rad.. - rachelholladay [more]
Unread 17-01-2009, 22:00
merybar's Avatar
merybar merybar is offline
AKA: Matt
FRC #0894 (Chargers Robotics)
merybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of light
Send a message via AIM to merybar
Fisher price for the drivetrain?
Our team is looking into switching from CIM's on the drive train, to the fisher price series. Anybody ever done this before? The idea is that with the significantly limited amount of friction this may work. Any thoughts?
Thanks everybody!
Team 894 Chargers Robotics
Unread 17-01-2009, 22:27
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
Re: Fisher price for the drivetrain?
i have done a Cim and Fisher Price drive tran and i think it would be fine as long as you don't really gear it high even on the low friction floor, you still have to get them moving.
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 17-01-2009, 22:36
merybar's Avatar
AKA: Matt
ok thank you!
Unread 17-01-2009, 22:49
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
Beware that the 9015 motor for 2009 ( and 2008 ) has significantly less power than those of earlier years. This years motor has a peak power of about 180W compared to 337W for the CIM. RPM on the FP's is about 3 times the CIM. You can turn an FP into a CIM mounting "thing" with an Andy Mark gear box. This might have sense for a drive motor (or 2nd drive motor) with the older FP's because there power was as least at a similar level.
The FP motors are fan cooled and so they need to spin. They easily overheat and when they do the plastic mounting slips making matters worse. You don't want to be anywhere near the right side of the power curve.
Generally, its better to use CIM's for drive motors and the FP for other things where you have better control over the speeds/loads etc. This year, you most likely need only a pair of CIM's leaving two for other uses.
If you do end up using them make sure you do the math. Also try to rig additionally cooling and make sure you have spares.
Unread 17-01-2009, 22:53
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
CIMS are definitely better than running the FP for the drivetrain, ........on carpet for sure.
This year's glassline surface.......try it and let us know.
Unread 17-01-2009, 22:56
Gamerboyb1's Avatar
Gamerboyb1 Gamerboyb1 is offline
Sean Goodrich (Sparx 1126)
AKA: Sean Goodrich (Sparx 1126)
FRC #1126 (Sparx)
Gamerboyb1 is an unknown quantity at this point
Send a message via AIM to Gamerboyb1
Oh, gosh who let Colin in here. Yeah that idea has won Sparxs so pushing wars over the years and using an Andymark planetary trannie with them helps to utilize them very well.
Unread 17-01-2009, 22:58
merybar's Avatar
AKA: Matt
I appreciate the help on this. I will defiantly check into the math,
Thanks
Matt
Unread 17-01-2009, 23:53
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Fisher price for the drivetrain?
Just to add another thought or two. Remember, you may be running on carpet at times on the perimeter, and the F/P motors do not like to be stalled. If you do use them, make sure you provide venting paths where you mount the motors. If you don't they will overheat quickly with no air movement even if they aren't stalled. Take a close look at the F/P gearboxes the motors are mounted on to see where the vents are located and sized. That is if you use different gearboxes.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 18-01-2009, 01:19
human
AKA: Colin Nobles
FRC #0148
good point keep um cool
-also make sure you press them in to the drive gear on the AM with up most care
-and a bit of grease applied to both motor bushings before you put them in to a gearbox can't hurt
Unread 19-01-2009, 16:47
Kit Gerhart's Avatar
Mentor, coach, whatever--
FRC #0233 ("The Pink Team")
I pretty much agree with what everyone has said. If you don't gear them too high, they should do fine on this low traction surface. I'd gear for not more than 10-12 FPS or so based on the no-load rpm of the F/P's, and gearing even lower would certainly be better for keeping the motors from getting fried.
Still, I'd use two CIM's for your drive unless you REALLY need them for other robot functions. They are so reliable that we go through a competition season, and then drive our robots for years doing demos and practice without having to replace CIM's on our drive.
Team 1062, The Storm, 2003
Source for Fisher Price Motors SRpowerhawks Motors 8 15-02-2010 12:52
Contact for Fisher Price AndyB Technical Discussion 2 16-01-2008 21:14
Buying parts for the Fisher-Price motors KrtZer0 Motors 3 11-02-2006 15:22
Heat Sinks for Fisher Price sanddrag Motors 10 08-02-2005 09:33
Trading for Fisher Price Motors Joe Johnson Kit & Additional Hardware 0 25-03-2003 14:57
