Go to Post We can't all be Dean. But with the right attitude and preparation, we can make careers out of our passions. - Richard Wallace [more]
Unread 17-01-2009, 21:14
elbuo elbuo is offline
Teams #2884 and #1144
AKA: Yamil Asusta
FRC #1144 (Coquitron)
elbuo has a spectacular aura aboutelbuo has a spectacular aura aboutelbuo has a spectacular aura about
Accelerometer Help?
I'm trying to use the accelerometer example to see if I can set a specific acceleration rate but everytime I run it over the cRIO it doesn't work. And I don't get the values it shows not even with the manual and 10 people reading it
Some help?
Unread 17-01-2009, 22:07
Re: Help?
When you say "it doesn't work," what do you expect it to do and what does it do instead? How do you have the accelerometer connected? Please give as much detail as possible so that we can all work together to narrow down the problem quickly.
Unread 18-01-2009, 09:44
AKA: Yamil Asusta
Re: Help?
I have the cRIO connected via wireless.
I was expecting that when I ran the .vi I could accelerate and it would show me the rate of acceleration but when I move my joysticks it doesn't do anything at all
I left the default settings cause I don't understand what they mean
Unread 18-01-2009, 10:14
Re: Help?
I'd check your wiring first. What ports are the accelerometer plugged into? Is that analog bumper working? Please fully explain your wiring.
What happens when you shake the accelerometer?
The settings indicate the middle point and the sensitivity of the sensor. Basically, they help map voltages to accelerations.
EDIT: Moderators - Can one of you please rename this thread?
Unread 18-01-2009, 10:46
pgaston pgaston is offline
FRC #2103
pgaston is an unknown quantity at this point
Re: Help?
A quick build on the last post. Are you using the dashboard? If not, do. This will help you ensure that your accelerometers are indeed working and plugged into the ports you think they are. (The dashboard helped us!)
Unread 18-01-2009, 10:48
AKA: Yamil Asusta
Re: Help?
Does the cRIO have an accelerometer...?
Unread 18-01-2009, 11:12
Re: Help?
No. The accelerometer is a separate board.
Unread 18-01-2009, 11:18
AKA: Yamil Asusta
Re: Help?
So that means we need to buy one right?
Unread 18-01-2009, 11:27
Re: Help?
No, one came in the kit of parts. It is a red board that is 1" square that says Accel on it.
It is shown on page 2 of http://usfirst.org/uploadedFiles/200...r%20Manual.pdf
Unread 18-01-2009, 11:45
AKA: Yamil Asusta
Re: Help?
Is it the piece connected on top of the cRIO. Connected to one of the slots?
The Digital one?
Unread 18-01-2009, 11:54
Re: Help?
No. The Accelerometer came in the padded manila envelope in the KOP and doesn't attach to the cRIO modules.
It needs to be physically wired before it can be attached to anything. It's just a bare 1" square circuit board.
Unread 18-01-2009, 12:38
AKA: Yamil Asusta
Re: Help?
Then we are missing it Cause I just went out to look for it and I didn't find it...
I'll keep searching....
After that I guess I'll figure my way out...
Also, I want to set a specific speed to the jaguars but I can't find where to do it.
I used all the motor examples available but none of them save the settings when I use the joystick...Any help?
Unread 18-01-2009, 19:26
Re: Help?
Someone should have done an inventory of your Kit Of Parts, using the 2009 KoP Checklist on the http://www.usfirst.org/community/frc...nt.aspx?id=452 page (find it under Section 10 - The Kit of Parts). Ask the person who did it whether your accelerometer board was missing, and where it got put if it was included.
I'm not sure I understand what you're asking. What does "save the settings" mean?
Unread 18-01-2009, 23:39
AKA: Yamil Asusta
Re: Help?
Yeah we are actually missing it.
All the teams from PR.
From what I read I can adjust the jaguars right?
I want to set a specific acceleration rate and a specific speed limit.
How can I do it?
Unread 19-01-2009, 10:47
Re: Help?
You had the chance to tell FIRST about missing KoP items the first week.
How can I do it?
You can't "adjust" a Jaguar the way you're describing it. What you can do is control its output, from full reverse to full forward and anything in between.
If you want to limit the maximum output, do it in software with a MIN() function. If you want to have a specific rate of change, do it in software by only changing the control value by a given amount in a given time until it reaches the desired value.
accelerometer help!! wildcats Electrical 2 18-01-2009 15:51
Help with accelerometer. ThisIsFood NI LabVIEW 6 17-01-2009 12:40
Accelerometer Help! Questions4mQ202 Electrical 4 15-01-2009 19:44
Accelerometer help Red Mage Programming 3 30-01-2008 18:49
Accelerometer Connection Help crazykid234 Electrical 2 11-02-2005 08:23
