Go to Post Raw students in, pure engineers out. - ebarker [more]
Unread 17-01-2009, 21:52
Hazmatt's Avatar
Hazmatt Hazmatt is offline
AKA: Matt
FRC #2645 (PowerSurge)
Hazmatt will become famous soon enoughHazmatt will become famous soon enough
Driving on carpet
So my team was driving around on a carpeted part of the shop today and spinning the wheels all over the place for about 5 minutes. When one of the mentors on the team went to go touch the chassis he got a pretty big shock from it. Apparently the plastic has the "wool socks on carpet" effect. Is this something I should be looking out for? I mean...some of the components in the kit came in special bags to protect against static shock, I would hate to ruin all the components on the board because I touched them . Anyone else experienced this??
Relax! It's only ones and zeros!
Unread 17-01-2009, 21:57
wilmo's Avatar
wilmo wilmo is offline
FRC #0868 (TechHOUNDS)
wilmo will become famous soon enough
Re: Driving on carpet
This also happens when running on REGOLITH. Every time we would go up to the robot we would get a decent static shock. It was much more prominent on carpet though.
Unread 17-01-2009, 21:59
Hazmatt's Avatar
AKA: Matt
is it something to be worried about? If the cRio and other components are insulated from the chassis does it matter?
Unread 17-01-2009, 22:01
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
how long were you driving for?
i wouldent want to chance it.......
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 17-01-2009, 22:02
Hazmatt's Avatar
AKA: Matt
I think it was only for 5 minutes, but like I said there was tons of wheel spin (like, donuts the whole time )
Unread 17-01-2009, 22:11
wilmo's Avatar
Which is totally unavoidable
I wonder if something like the vibration dampers on the "feet" of the compressor would help at all? (If it is a problem) It is my understanding that the bolt does not run all the way through the damping system thus making it insulated.
Unread 17-01-2009, 22:20
SammyKay's Avatar
SammyKay SammyKay is offline
Smentor all the way
AKA: Samantha
FRC #0316 (LuNaTeCs)
SammyKay has a spectacular aura aboutSammyKay has a spectacular aura aboutSammyKay has a spectacular aura about
Send a message via AIM to SammyKay
Oh jeeze. Are you serious?? Did FIRST think about the chance that it might cause static electricity??
Smentor of team 316, the LuNaTeCs and volunteer of the Bayou Regional 2012
Unread 17-01-2009, 22:27
Hazmatt's Avatar
AKA: Matt
Is it even a problem though if the electronics board is isolated from the chassis?
Unread 17-01-2009, 22:43
SammyKay's Avatar
Smentor all the way
AKA: Samantha
I dunno. It shouldn't be, I don't think. Mind you it is my first year doing electrical stuff.
Unread 17-01-2009, 22:45
Stormnnormn's Avatar
Stormnnormn Stormnnormn is offline
iPirate Poster
AKA: Norman
FRC #1528 (iPirates)
Stormnnormn is a jewel in the roughStormnnormn is a jewel in the roughStormnnormn is a jewel in the roughStormnnormn is a jewel in the rough
I can't envision it being any problem. It'll be a shocker if it is.
-Stormin Norman
Unread 17-01-2009, 22:50
CraigHickman
Posts: n/a
Shouldn't be a problem. Our 06 bot turned out to be an unintentional Van De Graph generator, so we could get a HUGE jolt by touching the frame after any match. Lucky we had a crazy freshman who kinda liked it!
wilmo's Avatar
I don't believe it will be a problem either, since most teams mount their electronics on lexan/polycarbonate, no additional precautions are really necessary.
Traction wheels on carpet generate static electricity too. We've usually put a short grounding strap/chain on our robot when practicing at our facility, just to keep from zapping the students. It sounds like we'll be needing one again this year.
Unread 17-01-2009, 22:58
Meredith Novak's Avatar
Meredith Novak Meredith Novak is offline
no team (Arkansas FIRST)
Meredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond repute
We have put one on the practice robot and it seems to be working.
Unread 21-01-2009, 20:55
Hazmatt's Avatar
AKA: Matt
So the wheels are stripping electrons off of the ground and giving the chassis a negative charge while leaving the ground positive. The opposite charges will then attract thus increasing the force of the robot on the regolith. Will this be counted as an extra traction device?
Carpet Renegade General Forum 7 06-04-2006 01:33
Carpet atmaturen General Forum 3 28-12-2004 12:36
Carpet??? Mandy_Candy General Forum 3 14-02-2004 10:35
Carpet? archiver 2000 2 23-06-2002 22:33
carpet friendly? sidewinder Off-Season Events 1 11-11-2001 07:06
