Go to Post There is a fine line between genius and insanity, watch your step! - Al Skierkiewicz [more]
Unread 17-01-2009, 20:43
frcchile's Avatar
frcchile frcchile is offline
FRC #2576
frcchile will become famous soon enough
Programing servo in Axis camera 206
Hello I´m from chile, My team is #2576 the name " chilean heart" I have the following question, I do not know how to program the servo in LabVIEW, I think that can be a connection problem. The example program doesn´t work not move the servo
What is the correct connection?
What is the correct programation in labview?
Thank you very much for help me !!!!
Unread 17-01-2009, 22:04
Re: Programing servo in Axis camera 206
Before chasing down possible programming errors, let's start with the simple questions. Did you install a servo power jumper next to the servo's PWM output on the Digital Sidecar? Without power, a servo will not work.
Unread 17-01-2009, 22:21
frcchile's Avatar
FRC #2576
I put the servo in the PWM number 10 and 9, no jumper Where is the jumper?
Unread 17-01-2009, 22:29
Ellery's Avatar Unsung FIRST Hero
Ellery Ellery is offline
Working on my 10 month old robot...
AKA: Ellery
no team (X-CATS - on Sabbatical)
Ellery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond repute
Send a message via AIM to Ellery Send a message via Yahoo to Ellery
You need to place a jumper in the slot next tot he PWM pin to enable the 6VDC to power the Hitec Servos. The Jumpers are included in the Controller Kit of Parts. Check the invetory list for a picture.
Good luck!
Xerox Sr. Systems Engineer
Other jobs: Retired X-CATS Team Leader, Inaugural FLR MC and plain ol' nice guy
Team# 191 X-CATS - Est.1992 (www.x-cats.org)
"We don't just build robots we build people..."
Unread 17-01-2009, 22:34
frcchile's Avatar
FRC #2576
Good luck!
Thank you !!!, I see where is the jumper but for not sure I did not want to try because I can burn it, tomorrow I going to put the jumper.
Should work with the example program and jumper?
GOOD LUCK !!!
Unread 18-01-2009, 08:50
frank.pendzich's Avatar
frank.pendzich frank.pendzich is offline
Mr.P
AKA: Mr. P
FRC #3011 (RoboWarriors)
frank.pendzich is an unknown quantity at this point
We're starting the color tracking today... We don't have a certificate of ownership needed to activate National Instruments Vision Assistance 8.6 for the axis camera. Where can we get a valid serial number to authenticate the installation of the software?
Unread 18-01-2009, 08:53
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
The serial number was either with the software CDs on the Cd case or on a sheet with them I cant remember which.
-Mike AA
Connecting Axis Camera Sauce Programming 8 18-01-2009 20:08
Model of Axis Camera Bochek CAD 2 18-01-2009 17:50
AXIS Camera nickmagus Programming 1 03-01-2009 20:06
Program Axis Camera in c++ excel2474 Programming 5 22-12-2008 17:14
axis camera - problem s0crates FRC Control System 11 16-12-2008 09:34
