Go to Post More resistors Igor! - BitTwiddler [more]
Unread 17-01-2009, 23:53
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Fisher price for the drivetrain?
Just to add another thought or two. Remember, you may be running on carpet at times on the perimeter, and the F/P motors do not like to be stalled. If you do use them, make sure you provide venting paths where you mount the motors. If you don't they will overheat quickly with no air movement even if they aren't stalled. Take a close look at the F/P gearboxes the motors are mounted on to see where the vents are located and sized. That is if you use different gearboxes.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Source for Fisher Price Motors SRpowerhawks Motors 8 15-02-2010 12:52
Contact for Fisher Price AndyB Technical Discussion 2 16-01-2008 21:14
Buying parts for the Fisher-Price motors KrtZer0 Motors 3 11-02-2006 15:22
Heat Sinks for Fisher Price sanddrag Motors 10 08-02-2005 09:33
Trading for Fisher Price Motors Joe Johnson Kit & Additional Hardware 0 25-03-2003 14:57
