Go to Post Hype levels are reaching critical levels... - wjd13 [more]
Unread 17-01-2009, 14:00
GunfighterJ's Avatar
GunfighterJ GunfighterJ is offline
AKA: Joseph
FRC #2450 (RaiderBots)
GunfighterJ is an unknown quantity at this point
Question Formula Problems
We need to implement a formula into labview. When using the Formula.vi and the formula window opens up to add the formula. We realized that there isn't an equal sign. Without one we can't make the formula work. Is there any way to add an equal sign without?
Unread 17-01-2009, 14:24
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
Re: Formula Problems
Open LV help and search for formula. Look at the formula node. It allows you to write C like code.
Unread 18-01-2009, 00:02
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
That Formula VI takes multiple inputs and outputs one output. Why do you need an equal sign?
What formula is this? The formula should only output one thing.. if it does, just rearrange it so the output is on the right side of the equal sign (on paper), and put the left side into the formula vi.
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 18-01-2009, 00:40
Luke Pike's Avatar
Luke Pike Luke Pike is offline
Programmer
FRC #1501 (THRUST)
Luke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to all
Check out this tutorial.
Chain Strength Formula Molten General Forum 5 18-04-2007 15:01
Need Help: Formula Needed Wilson Motors 21 30-12-2005 18:09
Help: a good, free formula writing software. suneel112 IT / Communications 4 13-08-2004 21:06
PSI formula for pneumatic pistons Ryan Pneumatics 10 13-01-2004 12:56
