Go to Post FIRST is like Starbucks coffee, it's addicting and you just can't seem to get away from it... - Beth Sweet [more]
Unread 17-01-2009, 13:56
RKElectricalman's Avatar
RKElectricalman RKElectricalman is offline
Meezy the Mentor
AKA: Rameez
FRC #0384 (Sparky 384)
RKElectricalman is just really niceRKElectricalman is just really niceRKElectricalman is just really niceRKElectricalman is just really nice
Send a message via AIM to RKElectricalman
Re: Two Color Tracking Demo
Can anyone explain to me how to open up the project in Wind River?
Also, when I was working with Labview, I couldn't get it to track. I figured out how to power the servos with the jumpers included, but I couldn't get the camera to actually autonomously move and track the colors, even though it did see it in the VI. Has any one had any issues similar to this?
ahhh Division Finalists!!
Unread 17-01-2009, 15:59
pollyproof12 pollyproof12 is offline
AKA: Jarrett
FRC #1865
pollyproof12 is an unknown quantity at this point
anyone have pictures of how they set up thier camera?
Programmer
Unread 17-01-2009, 20:14
nickmagus's Avatar
nickmagus nickmagus is offline
AKA: Nick Clayton
FRC #0008 (Paly Robotics)
nickmagus is an unknown quantity at this point
Send a message via AIM to nickmagus
nvm
Unread 17-01-2009, 20:26
laultima laultima is offline
FRC #1458 (Danvillans)
laultima is on a distinguished road
Send a message via AIM to laultima
The color values from this work beautifully. Weve got our camera tracking, both pan and tilt, from code we wrote using these colors in WindRiver. Ill be happy to post the code here if anyone wants to look it over.
2007 Davis/Sacramento Regional Winner (100, 997, 1458)
2008 Davis/Sacramento Regional Gracious Professionalism Award Winner
Unread 18-01-2009, 05:00
btgdaniel's Avatar
btgdaniel btgdaniel is offline
FRC #1731 (Fresta Valley Robotics)
btgdaniel is an unknown quantity at this point
Thumbs up Re: Two Color Tracking Demo
Yes, please post your code -- it would be nice to see another example.
Team 1731
Catch the FeVeR ~ If You Can!
Unread 18-01-2009, 09:48
A few clarifications. The example for two color tracking does need to have the DS connected and enabled, but it doesn't care if it is autonomous or tele. You can incorporate it into either or both later.
If you are having problems with the LV example, I'd be glad to help. The first thing I'd advise is setting the radio button near the image display to turn off the gimbal, so the camera will hold still and you will see what the camera sees. Make sure it is focused, make sure your target is in the scene. And hopefully the mask display below will show you the results of the red/green thresholds.
Lighting has a huge impact on vision, and even though this is app was written to be really tolerant of lighting, it can still mess with you. So I usually tilt the target forward and back a bit to see how that will affect things. Move it around to see how overhead lights affect things. Splotchy lighting is some of the worst.
If you are having difficulties at this point, it will be necessary to adjust the camera settings, no use trying to track.
Greg McKaskle
Unread 18-01-2009, 19:44
Dr Nick Dr Nick is offline
FRC #0501 (The Powerknights!)
Dr Nick has a spectacular aura aboutDr Nick has a spectacular aura about
Send a message via AIM to Dr Nick
I've got the camera mounted and scanning for the target but it won't lock on to it (using C++). I got an image from the camera and set the threshold values for my lighting conditions so i have no idea why its not working. To make matters worse, there is a problem with DPRINTF (I think). When it got to the DPRINTF command, the console said there was an error with it, saying a malformed calling sequence. Is anyone else having this problem?
Unread 19-01-2009, 13:44
Mikesername's Avatar
Mikesername Mikesername is offline
meh.
AKA: Mike Dame
FRC #3044 (Team 0xBE4)
Mikesername is an unknown quantity at this point
Send a message via AIM to Mikesername
So how do you go about hooking it up so the motors attatched to the wheels move to follow the target?
[ ballston spa robotics | www.team3044.com | team BE4]
Unread 19-01-2009, 14:16
Ted Weisse's Avatar
Ted Weisse Ted Weisse is offline
AKA: xMentor/Inspector/Referee
Ted Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of light
Greg McKaskle[/quote]
We can track a single color and the example when in camera mode sees both red and green thresholds. When we enable the gimbal and the DS the pan/tilt searches. On the screen we see the green lagging the red target as it goes across the screen.
What are we doing wrong?
Thanks....
If I am not for myself, who will be for me?
If I am not for others, what am I?
And if not now, when?
-Rabbi Hillel
Jewish scholar & theologian (30 BC - 9 AD)
Unread 19-01-2009, 17:47
Heres the code we're using for target tracking, using the color values from the TwoColorTrackDemo. All variables are doubles declared before the While loop, and pan and tilt are servos.
if (FindColor(IMAQ_HSL, &redData.hue, &redData.saturation,
					&redData.luminance, &aRed) && FindColor(IMAQ_HSL,
					&greenData.hue, &greenData.saturation,
					&greenData.luminance, &aGreen)) {
				redX = aRed.center_mass_x_normalized;
				redY = aRed.center_mass_y_normalized;
				greenX = aGreen.center_mass_x_normalized;
				greenY = aGreen.center_mass_y_normalized;
				centerX = (redX + greenX)/2;
				centerY = (redY + greenY)/2;
				panMove = (tan((PI/4)*centerX))/8;
				tiltMove= (tan((PI/4)*centerY))/8;
				pan->Set(pan->Get()+panMove);
				tilt->Set(tilt->Get()-tiltMove);
Unread 19-01-2009, 21:38
Are you holding the target so that it looks like a foe? The panel lets you describe which alliance you are on, and by default it looks for and tracks the biggest foe.
Greg McKaskle
Unread 19-01-2009, 21:57
Ted Weisse's Avatar
Yes as foe. The servos just hunt never locking on to the target.
-Rabbi Hillel
Unread 19-01-2009, 22:28
If the red and green masks look good, and your holding the target in the correct orientation, the next things I'd do is to watch the Tracking State indicator. When the camera doesn't see the target, it should search. When it acquires some pink and green that make up a foe, it uses the proportional constants to move the camera so that the target is closer to center. You may want to check the sign of the constants to see if the servos are moving in the wrong direction.
If you don't stumble on the issue soon, one thing that will help with debugging will be to put the target in frame, but off center. Position the servos with the FP knob and slider if you need to. Then put a break point after the FindTwoColor and follow it into the Servo Track VI to determine which of these is the issue.
Greg McKaskle
Unread 20-01-2009, 19:13
rcoren22's Avatar
rcoren22 rcoren22 is offline
FRC #0223 (Xtreme Heat)
rcoren22 is a splendid one to beholdrcoren22 is a splendid one to beholdrcoren22 is a splendid one to beholdrcoren22 is a splendid one to beholdrcoren22 is a splendid one to beholdrcoren22 is a splendid one to beholdrcoren22 is a splendid one to behold
we are able to see get colors in mask, with tracking indicators showing position and target numbers, but we cannot get any ouput to servo motors.
We have connected servos to pwm 9 and 10
Is the target numbers what should be outputed to servo pw9 & pw10
The illiterate of the future will not be the person who cannot read. It will be the person who does not know how to learn.
Alvin Toffler
Unread 20-01-2009, 19:38
Booksy Booksy is offline
FRC #1244 (Viking Robotics)
Booksy will become famous soon enoughBooksy will become famous soon enough
Forgive me if this has been mentioned before: Does the servo updating loop have a watchdog feeder. This has been the problem for me numerous times. It might already have it, I forget, but I know the first one (single color) didn't and I had to add it.
My favorite CD quote ever(taken out of context of course):
Originally Posted by ttldomination
water would be hard to build
Camera tracking between two lights Ankush Dhar Programming 2 12-02-2007 23:44
Tracking two lights Render Programming 5 29-01-2007 18:14
Camera tracking demo in easyC or WPILib BradAMiller Programming 0 25-01-2007 14:01
Tracking Color? haywirerobotics Programming 0 14-01-2006 13:55
tracking two tetras? Anton Programming 5 09-02-2005 15:02
