Go to Post It would be interesting to be able to take robots from multiple years and invent new games they can play together (Calvin Ball). - Mark McLeod [more]
Unread 18-01-2009, 10:47
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Re: DS always disabled
Although it wont help you, as you have probably tried both switch positions, but the "enabled" position on the toggle should be up, not down.
Team 2052- KnightKrawler
Mentor and volunteer
Unread 18-01-2009, 14:38
intellec7's Avatar
intellec7 intellec7 is offline
108 programmer
AKA: Gustavo
FRC #0108 (SigmaC@ts)
intellec7 is on a distinguished road
Send a message via AIM to intellec7 Send a message via MSN to intellec7
Mark, that helps tremendously. Thanks! We have flashed the DS twice with the firmware.. We'll be contacting the KwikByte support.
Tanis, we opened the switch and probably mounted it back in backwards without realizing heh.
Unread 07-02-2009, 16:56
Terry Sherman's Avatar
Terry Sherman Terry Sherman is offline
Mentor -- Software
FRC #0093 (NEW Apple Corps.)
Terry Sherman is an unknown quantity at this point
We are having the same issue. Any luck contacting Kwik Byte? Any solutions offered?
We have the latest driver stations update (2009_01_22c1) as well as NI Update 3a.
When we turn on our Driver Station without anything elase other than power and the enable/disable switch, we can change from disabled to enabled.
When we add in the PC's ethernet, it still works.
When we connect *either* the cRIO via ethernet or connect the router via eithernet the DS will not exit disabled mode.
-Terry Sherman
Team 93 Software Mentor since 2003
Unread 07-02-2009, 17:20
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
I think it is the new update. Both of ours were fine before the update, now they both lock in"disabled" whenever we are connected to the cRIO. Does anybody have a copy of update 2? at least that one worked.
Former Mentor Team 1771
Former mentor Team 4509
Unread 08-02-2009, 13:20
I've seen this when the cRIO was at Update 2 and hadn't had Update 3a installed.
Restoring to the Oct DS firmware release does work, but reimaging the cRIO should work.
Unread 10-02-2009, 19:54
DillonMartine DillonMartine is offline
FRC #0417
DillonMartine is an unknown quantity at this point
Also, For some reason, If you remove the watchdog, the Dongle switch for the DS does not work. When the code for the watchdog is added again, it functions normally.. Strange.
Unread 10-02-2009, 23:49
I'll have to try that one. That's good to know. Thanks.
pic: Always Come Prepared A_Reed Extra Discussion 6 26-03-2007 14:22
WE LOVE YOU ALWAYS BrendaB Thanks and/or Congrats 0 29-02-2004 08:19
pic: Working Hard, As Always CD47-Bot Extra Discussion 4 14-04-2003 09:07
always good teams nuggetsyl General Forum 1 10-01-2003 22:20
HELP! is always available at NATs archiver 2001 0 24-06-2002 03:04
